Go to Post Math is always fun, especially when it's useful. - Guy Davidson [more]
Unread 10-01-2007, 00:11
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Belt Configuration
Just wondering what anyone thought about this belt configuration? would it work? any suggestions?
Unread 10-01-2007, 00:15
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Belt Configuration
eeek.
i did like how you had the idler in the front. i would then repeat that in the rear too, therefore the middle sprocket will have more contact and thus less prone to slipping. it's a good start.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 10-01-2007, 00:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Perhaps the middle pulley is an idler? if it's driven, then the design won't work very well.
Unread 10-01-2007, 00:22
Hadi379's Avatar
FRC #0379
Thanks, but putting an idler on the other end might not be feasible because the belt we have is custom made to length. slippage is minimal due to the teeth in the belt meshing with the teeth in the wheels. Our previous configuration had less contact with the wheels. thanks again for your input
Hadi379's Avatar
FRC #0379
the only drive wheel is the rear wheel, or far right wheel in this case.
Unread 10-01-2007, 00:23
Hadi379's Avatar
FRC #0379
the remaining wheels are idlers
Unread 10-01-2007, 00:35
If I understand your design correctly, I would switch the powered roller from the right to the left. That would make it so the roller that is being powered will be the one with the most degrees of contact with the belt.
Unread 10-01-2007, 02:03
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I think you're fine as is if the rightmost pulley is driven. You won't see a performance gain for the extra few degrees of wrap the front gives you.
Is there any reason why you're using unpowered timing pulleys in the middle and leftmost locations? They're not driven, so they don't need teeth. Similarly, they could also stand to be smaller.
Finally -- don't forget to make use of the EDIT function at the bottom righthand side of all of your posts. It helps to keep the forums clean and makes it easier to find information while searching.
--Madison--
...down at the Ozdust!
Unread 10-01-2007, 02:57
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
what would you use this for anyways?
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Configuration File? FFnut Programming 2 03-02-2006 17:38
Check All option on Recent Activity Configuration sanddrag CD Forum Support 0 29-01-2006 22:35
Victors, Default code, & joystick configuration Vermatitis Electrical 4 27-01-2005 16:01
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
