Go to Post For any coaches weary of choosing human players this year because you're worried they might lose their cool mid-game, a good indicator of someones ability to keep focused is their attitude while playing video games. - BradMello [more]
Unread 10-01-2007, 03:37
fauxnominal fauxnominal is offline
fauxnominal is an unknown quantity at this point
pwms
hi all, i'm new to FIRST, but not programming.
i've read all the recommended reading as per mark mcleod and whatever else i could dig up online.
i know how to program in c and have a little bit of an idea as to how things work.
what i still don't understand is, does pwm<integer goes here> == pin<$1>?
i should also mention that i like to work under linux and know that the 2.4 compiler works under wine, but can i load the hex output into the robot using ifiloader in wine?
all help is appreciated.
cheers
Unread 10-01-2007, 03:46
Umm Errr...
Re: pwms
cheers
I don't really understand the first question.
As for the second about ifiloader, sciguy125 wrote a linux port called IFI Loader Reloaded. http://www.chiefdelphi.com/forums/sh...ad.php?t=38853
1139 Alumni
Unread 10-01-2007, 03:47
Tureyhall Tureyhall is offline
AKA: Thomas Hall
FRC #0668 (Apes Of Wrath)
Tureyhall will become famous soon enoughTureyhall will become famous soon enough
Re: pwms
pwm01 is the first pwm 3-pin set. I don't know if that's what your looking for, but ok. A slightly better explanation would be nice.
/*Nerd Camouflage*/
2005 SVR - 668+1072+840 - Semifinalists.
2006 SVR - 668+1280+1693 - Finalists.
2007 SVR - 668+604+624 - Quarter-finalists, Xerox Creativity Award, two highest scores (290-2, 128-0) at SVR.
2007 Nat's - TBA.
Unread 10-01-2007, 04:25
Re: pwms
that was really weird short hand for pwm01 == pin01?
it would be nice if there was some sort of chart that displayed all of that, not just for pwm outputs of the rc but of the camera, etc.
Unread 10-01-2007, 07:00
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pwms
The PWMs pins are in a 3x16 row. Each column of 3 is one PWM. One pin is the ground, one is the power and one is the signal. If you have any questions dont hesitate to ask.
Unread 10-01-2007, 08:59
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: pwms
I think what your are asking is how to turn on a motor. Just setting the variable pwm01 will turn on (or off) the motor connected to the first pwm output. The reason all you need to do is set it is because that variable is returned to the master controller and it "writes" it to the register that turns on the motor.
In the default code its just set to the value from the joystick:
pwm01 = p1_y;
Note: to turn a motor off, set it to 127. Values less than 127 are reverse, values greater than 127 are forward. Its range is 0-255.
You can see all the variable you get for input and that you can set for output in the header file ifi_aliases.h
Brian
Unread 10-01-2007, 09:10
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Re: pwms
For programming in linux you can also use picloader to flash the controller. It's available from sourceforge: http://sourceforge.net/projects/ifi-picloader. There's no gui with this, but you can use a text mode view with it if you use picloader_textmode.
Unread 11-01-2007, 09:07
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: pwms
Assigning a value to a PWM output is not the same as turning a digital output on or off. PWM<x> is a data variable in the block of data which is passed back to the master microprocessor. The master microprocessor handles the radio link and generating the motor signals (there is a way to directly control some of the motor signals, but lets not worry about that at this point). PWM stands for Pulse Width Modulated. The signal on the pwm pin is a stream of pulses at a frequency of about 50-55Hz. The width of the pulse varies between 750 us and 2250 us. A 127 value to the pwm variable generates a pulse width of 1500 us and the motor response to this no movement. A 0 value is full speed in one direction and 255 is full speed in the opposite direction.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 12-01-2007, 04:38
Re: pwms
i think what i am confused about the most is how does all the wiring work?
i think code wise i am fine, but when it comes time to test the code, i'm going to have a lot of problems. where do i connect what to make interrupts work beyond the software abstraction?
thanks for all the responses thus far. they are much appreciated.
Good-looking PWMs: is it possible? Chriszuma Electrical 2 10-02-2006 00:25
PWMs Active in Programming Mode? ldeffenb Control System 4 14-01-2006 07:35
pwms for relays reilly Motors 3 18-02-2005 15:02
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
Mapping Buttons to PWMs actorindp Programming 9 10-02-2004 11:11
