Go to Post the robot is never done that it just evolves less rapidly - sporno [more]
View Poll Results: Pick which in your opinion is better: Scissors Lift or DoubleJointed Arm
Scissors Lift 26 29.89%
Double Jointed Arm 61 70.11%
Voters: 87. You may not vote on this poll
Unread 10-01-2007, 01:20
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
Re: ScissorsLift vs. DoubleJointed Arm.
Originally Posted by Guru View Post
I believe energy storage through springs is perfectly legal, although i cant find the rule right at this moment.
Robot Rules, 8.3.1 General Design & Safety Rules
Under <R02> (about energy used on the robots--one of 4 permitted energy sources):
"Storage achieved by deformation of ROBOT parts. Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe."
In summary, SAFE springs are legal. The definition of a spring seems pretty broad. I believe a spring is safe if it is:
1) Not likely to break
2) Well secured at both ends
3) A suitable strength for the application.
Humorous illustration: There was a fiction piece in the December 2006 Boys Life magazine about a boy who designed a revolving Christmas tree using a wind-up mechanism powered by an inner tube. He did not have adequate restraints on his device, as he learned when he released the catch...
Karen Husmann
Ex Robo-widow
Unread 10-01-2007, 04:28
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
no talk of elavators!?! =O
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 10-01-2007, 07:24
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Originally Posted by Cody C View Post
These pictures are for you ... They are all "effective" scissor lifts. All that is needed to reveal a wealth of effective Ideas is a look into the past.
Some of what has been being said in this thread is nothing but a bunch of rash generalizations. If you look into Industry... you will see numerous instances of scissor lifts being used, because they are good at what they do. some mechanisms are better than others at certain tasks, It all depends on the application.
You can't just say: "Scissor lifts aren't good because they haven't been made to work yet. They will always be inferior. " It doesn't work that way.
Taken from HERE
Taken From HERE
Funny you chose this picture... I was going to post how our team used a scissor lift in our rookie year and we found it easy to build and easy to use. It was fairly light & worked well enough. We connected across the joints with surgical tubing to give it that "spring" you talk about. The lift is still together but not attached to the base. Arms can be a challange.
Unread 10-01-2007, 08:37
GaryVoshol's Avatar
Cogito ergo arbitro
//pictures snipped for space//
Taken From HERE
Wow, they let those go without pinch-point protection?
(since 2004)
Unread 10-01-2007, 09:35
USAF Capt. Sean's Avatar
USAF Capt. Sean USAF Capt. Sean is offline
FRC #1675
USAF Capt. Sean is an unknown quantity at this point
From what i can tell is that scissor lifts are more stable and can handle more weight. Plus the scissor lift can colapse down to under 10" and extend to over 90". by far this is way better then a double jointed arm.
Unread 10-01-2007, 09:54
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
The debate of arm vs scissor has two views:
Scissor Lift:
It is an inherantly more complex *Mechanism* since there are multiple sets of moving parts. If one small roller fails, the whole mechanism could be broken. That being said, the actuation of a scissor is simple in that it just takes a pneumatic cylinder or screw drive. Control is easier since it is a single input, but speed could be slower depending on actuation method.
Articulated Arm:
This is a simple *Mechanism* since there are only one or two moving parts involved. The control of an articulated arm poses a greater problem since you have to learn how to control different sections of the arm to create different motions. Sometimes, there are multiple positions of the arm that can get to the same point, so you need to plan on how you are going to move it.
In terms of strategy, simplicity, and usefullness, I would put my vote towards an articulated arm.
If our team has an arm, we will most likely do articulated.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 10-01-2007, 10:32
DonRotolo's Avatar
Back to humble
FRC #0832
For the application of lifting a robot (or two) 12 inches, none of the sway problems stated above would really apply to the situation,
For a scoring arm, however this would be an entirely different story...
I think the choice of arm or lift was meant for a scoring system, not a robot lift, but I admit it's completely ambiguous given this year's game... Ain't it fun?
Don
Unread 10-01-2007, 13:52
ChrisH ChrisH is offline
Generally Useless
Either approach can be made to work but there are a few things you need to understand.
Scissor Lift
These require tight joints that only move the way intended. Sideways slop in your pivot joints will make the structure completely unmanageable. The members of the lift must also be pretty stiff, they cannot deflect much under load. Again deflections can make the lift unmanageable.
Another thing to consider is that the lower the scissors lift gets, the more force is required to raise it. The force required can be several times the weight of the lift and the object you are lifting combined. That is why springs connecting the joints help so much, they apply force in the direction needed.
However you only have one thing to control and it should be fairly easy to get precise positioning if you use a ball screw or something similar to activate the lift. This can be a real advantage if you are trying to acheive a precise height.
Double Jointed Arm
The double jointed arm has many fewer parts. This will make it structurally much easier to build than a scissors. But it will be much more difficult to position precisely. This is because a small variation in the angle of the arm at the pivot will result in a large displacement at the end of the arm. Now add the uncertainty of the second joint to that. You will get a fairly large uncertainty in your vertical position. You will also have a similar uncertainty in your horizontal position
You might have trouble resolving the joint angle sufficiently acurately to achieve precise position control. Then you will have to rely on your arm driver to compensate.
The higest stress on the arm will be when it is fully extended horizontally. Be sure that the arm will move upwards from this position while carrying a payload. Your operator may know that he or she should not exceed a certain limit to prevent arm failure. But I can guarantee that sooner or later they will make a mistake and the dreaded full extension will occur.
Christopher H Husmann, PE
"Who is John Galt?"
80/20 arm Lil_moe Technical Discussion 2 05-02-2005 09:05
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
MY ARM!!! Jeff Rodriguez Chit-Chat 6 18-05-2002 20:24
