Go to Post RoboRIO brownout (v, n): The GDC's alternative to limiting the number of motors allowed on a robot. - GeeTwo [more]
Unread 09-01-2007, 23:44
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
First Time Pneumatics
Hi. Using pneumatics for the first time.
Question 1. How practical is it to just have tanks and not carry the compressor around? I know it depends on how much pneumatic motion you have, but given past competitions, has that proved practical?
Question 2. If the compressor is not on board the robot, I understand that it has to still be powered and controlled by the robot. How do you connect / disconnect the air?. Can a "quick coupling" type connector be used?
Question 3. According to <R103>, the wires from the Nason pressure switch must be connected to a digital input on the robot controller, and then the robot controller must control a spike with a relay output to turn off the compressor. Why won't they just let us put the pressure switch in series with the control signal for the spike and not have to worry about the controller turning it off? The software is no big deal, but I'm thinking about when the controller is being programmed, or freezes up, etc.
Thanks
Brian
Unread 10-01-2007, 09:37
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: First Time Pneumatics
1. If you are using a small volume of air it is reasonable to use just the storage tanks. If you know how frequently you will actuate the pistons you can calculate the air volume and storage pressure necessary using the ideal gas law (P1)(V1)=(P2)(V2)
2. Use one of the pnuematic fittings prvided and charge through the vent valve. This is pretty much the only legal way because of the restrictions pnuematic parts. A quick connect won't pass inspection if it didn't come in the kit.
3. It's been argued frequently and it comes down to this is the way FIRST wants it done. Also I don't believe the PS is rated for the current.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 10-01-2007, 10:04
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Look here for the Nason model SM pressure switch ratings. Looks like the switch is rated for 5A, so it appears that SuperBK's suggestion (which many others have made before) would work. But as has already been pointed out, the rules that cover pneumatics connections for FRC robots are very clear. I guess that FIRST requires direct connection of the SM pressure switch to a RC digital input in order to simplify inspection -- it makes the wiring easier to trace. It also helps prevent a potentially dangerous connection of the pressure switch in series between one of the the compressor electrical leads and the Spike relay.
Richard Wallace
since 2003
Unread 15-01-2007, 21:53
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Thanks
Brian
It is ideal to have the compressor on the robot due to the tanks, because they do not store that much air. If you arent using that much air then I would go with just the tanks.
Unread 15-01-2007, 22:33
Keep in mind, O veteran, that storage capacity is now FOUR tanks instead of two.
Then again, what is the air being used for? Shifting? No problem. Ramp deploying only? No problem. Actuator for tube gripper? Might be a problem. Combination of above? You need onboard compressor.
Unread 15-01-2007, 22:40
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
We have decided to put the compressor on board this year. We have 4 solenoids that are in use to simply pick up and drop tubes. This requires an air compressor.
Maybe we should start a poll; How many teams will have a compressor on board. This would not be useful in any way other than seeing the statistics. However it would be interesting to see how many teams have a tube grabber design that use pneumos...
Jacob
Unread 17-01-2007, 20:22
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
Cool Re: First Time Pneumatics
does any one know when they are coming
**FIRST EMAIL**/SMC Pneumatics and 2007 FRC Game Pieces Purchasing Information Rich Wong FIRST E-Mail Blast Archive 9 06-01-2007 07:31
FIRST time FIRST is in CEPHAS Carlos Felipe General Forum 3 14-12-2005 17:53
FIRST in Time Magazine? Dr.Bot FIRST In the News... 3 02-02-2005 23:19
FIRST Time Autonomus Help rcubes85 Programming 1 22-01-2005 11:52
Time Magazine mentions FIRST Venkatesh FIRST In the News... 5 29-12-2004 23:25
