Go to Post No way thats Dean... he didn't give an hour long speech :p - AndyB [more]
  #31   Spotlight this post!
Unread 09-01-2007, 15:13
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Re: <G09> Dropping Tubes on Your Opponent
Originally Posted by Kris Verdeyen View Post
Something more likely to happen, and less likely to elicit FIRST's sympathy, is the very real possibility that a team might drop a tube in a way that it is hung up on their own robot, but still impossible to score or dislodge. In this case, a robot might just be hamstrung for the match, unable to pick up another tube.
And that's when you launch plan B: the power to push an opposing robot sideways across the length of the field. Too bad the kit doesn't come with skyway wheels anymore....
  #32   Spotlight this post!
Unread 09-01-2007, 15:43
Choi9111's Avatar
Choi9111 Choi9111 is offline
(^_^)v I ROCK!!!!
AKA: BAKA!!!!!!!!!!!!!!!! (Tomo) >_<
FRC #0932 (Leviathan)
Team Role: Driver
Choi9111 is on a distinguished road
I think that you might get a yellow flag if you drop it on an opponent on purpose...other than that, IDK?!
I AM Leviathan...only not as green and slimy...and i only have 4 limbs not 8...wait technically im not leviathan at all...>_<,
  #33   Spotlight this post!
Unread 09-01-2007, 16:13
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
i'd pick a yellow card team that did that,
does anyone know if you have a yellow card at the end of the Q's does it go away for the Eliminations,
hopefullly, this is the case
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
  #34   Spotlight this post!
Unread 09-01-2007, 16:39
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: G09 Questions
I don't think it will matter. I don't see the refs going "Oh, a robot dropped a tube on your robot, you have 2 tubes, YOUR GOING DOWN!". I wouldn't worry about it. The other guys tube is quite useless to you, you can't score with it or anything.
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
  #35   Spotlight this post!
Unread 09-01-2007, 20:11
KevinH's Avatar
KevinH KevinH is offline
AKA: Kevin Hamer
#1307 (STAR (Labs))
KevinH will become famous soon enough
Send a message via AIM to KevinH
This rule deserves clarification at minimum.
  #36   Spotlight this post!
Unread 09-01-2007, 20:40
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
I think that it is a perfectly legal and legit strategy, but I can see FIRST redeclaring it as illegal similar to the situation in 2005 with the loading zone penalties and teams intentionally backing up into passing teams to inflict high penalties points.
RTM its in there...
Section 9- The Tournament
Page 8 of 9
Rule <T09>
Originally Posted by The 2007 FRC Manual
<T09> YELLOW CARDS do not carry forward between qualification matches and elimination
matches. All teams move into the elimination matches with a clean slate.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
  #37   Spotlight this post!
Unread 09-01-2007, 20:53
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: G09 Questions
Originally Posted by trilogism View Post
So could your robot be designed to put the ringers on your opponents, who then receive penalties for possesing more than one ringer?
Edit: I know that this is against FIRST spirit
I would consider a robot like this can be violating the rule of robots that can't be built for the destruction of other robots.
I would think and hope the refs would understand if a ring accedently falls on your robot and you can't remove it.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #38   Spotlight this post!
Unread 09-01-2007, 23:03
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Originally Posted by Tristan Lall View Post
Robots may extend vertically; you could take advantage of that to devise a protective device, if you felt it necessary.
Can you do this? Does your flag have to be at the top only at the start of the match, at which point you could actuate it to "safety", or actuate something over it to "protect" it?
Obviously if you extend beyond it, it will no longer be at the top, and I haven't seen anything saying the flag needs to be above the highest point on the robot yet...
  #39   Spotlight this post!
Unread 09-01-2007, 23:27
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You can temporarily extend things above the height of the flag. Not that you'd necessarily want to do this, but you could build an appendage that extends a COTS umbrella over your robot, to make it tougher to drop the tubes on the robot. As long as it was movable and not locked in place for most of the match, you'd be protected.
  #40   Spotlight this post!
Unread 10-01-2007, 07:13
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is online now
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Every team will have a 3' high flag on their bot. This is a potential object that the rings can drop onto your bot and not be easily removed. FIRST will probably come out with an update soon (I hope)
BTW, how many rings do you think will fit onto the flag?
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #41   Spotlight this post!
Unread 10-01-2007, 11:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: G09 Questions
The key word is control: If you cannot control the ringer, you don't 'possess' it.
But, this is for FIRST to clarify.
  #42   Spotlight this post!
Unread 10-01-2007, 12:11
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: G09 Questions
FIRST defined possession of a tube to be contact with it at more than one point, so you don't NEED to control the tube to possess it.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
  #43   Spotlight this post!
Unread 10-01-2007, 12:21
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: G09 Questions
can you referance this? i've read though the rules and didn't spot anything relating multiple points of contact to possession; i agree with don rotolo: control is the key to possesion.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
  #44   Spotlight this post!
Unread 10-01-2007, 12:26
AKA: James Letendre
Re: G09 Questions
woops. I was reading the on the floor part of possession.
However it does say if the robot is supporting the ring it is possession
POSSESSION: a GAME PIECE is considered to be in the POSSESSION of a ROBOT if it is
being fully supported by the ROBOT
, or if the ROBOT is controlling the position and movement of the GAME PIECE. A GAME PIECE on the floor is considered to be in the POSSESSION of a
ROBOT if it contacts the ROBOT at more than a single point (e.g. the ROBOT has a concave
"plow" feature that is used to push the GAME PIECE in a controlled manner)
Sitting on top of tubes notquitehere188 Rules/Strategy 23 08-01-2007 02:03
S.O.A.P (SigmaC@t Opponent Analysis Program) Arefin Bari General Forum 27 11-12-2005 14:13
Dropping a Regional w_b305 Regional Competitions 1 13-01-2005 09:51
dropping balls Joe Ross Math and Science 18 25-08-2004 22:40
Scoring when an opponent is in contact with your tallest stack. Randy Ai Rules/Strategy 1 06-01-2003 17:17
