Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
Unread 10-01-2007, 15:13
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
Re: Problem with program uploading
1573,
Can you tell us: what is the error message?
when does the error message occur? (after you press what button?)
What have you selected from the drop-down list of COM ports?
What shows up in the status bar of the window?
Can you post a screenshot of the error?
-- by the way,
Is your "program led" always orange? even before you press the "prog" button?
Good luck!
David A.
Program Build Problem douglass1371 Programming 3 18-02-2006 18:46
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
program download problem zdeswarte Programming 5 23-03-2005 06:46
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
