Buying Aluminum rectangular tubing
I'm looking for some rectangular tubing in sizes Mcmaster doesn't carry. What are some other good suppliers of rectangular tubing?
Re: Buying Aluminum rectangular tubing
onlinemetals.com
We have good success finding most of what we need at onlinemetals.com. Also, consider changing your design to use a more common size so that, should you need to replace some or all of it during an event, you'll have less trouble finding a supplier of it. |
What about 1/16" wall thickness specifically?
I'm looking for 1/16" wall in; 7/16" x 1 5/8" 2" x 1" 2" x 2" |
For something as big as 2"x1" or 2"x2" you might want to consider bending sheet metal and riveting it together |
Check out coast aluminum. www.coastaluminum.com
They are in Santa Fe Springs. Check out their online catalog but also call to see if they have anything new or different. We have purchased both 1x2 and 2x2 .062 wall locally here in LA. The likely hood of finding something like 7/16 x 1-5/8 is very slim. You can also check out Fry Steel, and Industrial Metal Supply both have locations in the LA area. Last edited by Kirk : 10-01-2007 at 19:02. |
#7
Thanks for the help everyone. |
| [OCCRA]: 2" aluminum square tubing.. | mostunsuspected | OCCRA | 5 | 13-09-2004 19:08 |
| steel tubing | BBFIRSTCHICK | Rules/Strategy | 2 | 14-01-2003 22:03 |
| Aluminum Tubing | archiver | 2000 | 2 | 23-06-2002 22:35 |
| Tubing | pfortunejr | Technical Discussion | 6 | 11-01-2002 08:10 |
| does small parts sell rectangular aluminum tubing | mnkysp6353 | General Forum | 2 | 09-12-2001 01:28 |
