#31
Re: <R12> 72" x 72" Size Restriction
While we're on the subject, front and back are not especially meaningful, except that to comply with the rules, teams will arbitrarily designate them (e.g. to place the diagnostic light). |
#32
Actually width and depth are clearly defined in most situations by <R07> (see chart on page 8 of Section 8). The width is your 28" dimension, and depth is your 38" dimension. Unless one of those dimensions is rotated in your starting configuration, I doubt it would be allowed to be rotated later.
#33
i might be wrong, but that definition only is for the starting configuration of the robot. Look at this example. A robot expandes to the full 6x6 square. it has an arm that is in the bottom left corner and ends in the top right. how is that any different from making a square robot with that length arm and making it fit diagonally.
correct me if im wrong. -coop, team 1717 |
#34
Re: <R12>
the arm cannot extend beyond the footprint. the footprint=a shadow of your robot straight below it. -coop, team 1717 |
#37
![]() Edit: On the solstice. ![]() |
#38
And the Q&A comes through. The answer is that the robot must fit inside a 72" x 72" x infinity virtual box at all times. So the diagonal trick works. I suppose still under question is whether it must be designed mechanically to never exceed the size, or whether it can be a driver/controls thing.
#39
Did I hear someone mention flux integrals ?! hehe |
#40
We had to back out of the West Michigan Regional due to lack of $$ - now we're going to have to travel to the Equator?
FedEx ought to love that one. |
#41
They can't enforce a mechanical limit because of the home zone rule. Also, there are software limits. If the pots on an arm limit the movement to a legal range, it would be crazy for the inspectors to make the team fully expand it. If the inspectors ask my team that, i will state "Sir, we can't make our robot do that, it simply isn't possible with our software" or something along those lines. |
#42
Re: <R12>
I think it means to make believe you are playing in a 72 x 72 square test tube. The test tube goes from the floor all the way to the ceiling of the arena. |
#43
Re: <R12>
-Guy |
#45
I think the max arm length will be based upon those who have a turret and can position the robot in a corner of the 72" square, and extend the arm to the opposite diagnal corner.
The issue then becomes interesting when the turret rotates, but that will be for our programmer to figure out!!! |
| Is there a restriction to what sensors we can use? | Robot Dude 0101 | Kit & Additional Hardware | 28 | 11-01-2005 22:43 |
| height restriction on pits | nzj1 | General Forum | 10 | 09-01-2005 21:34 |
| size limitations D: | Kevin Karan | Programming | 6 | 20-03-2004 21:20 |
| size | great_one411 | General Forum | 3 | 06-02-2003 09:02 |
| Ball size? | archiver | 2000 | 8 | 23-06-2002 22:24 |
