Go to Post Math is always fun, especially when it's useful. - Guy Davidson [more]
View Poll Results: What is the approach angle of your ramp (floor to ramp)
< 10 degrees 15 10.00%
10 to 15 degrees 36 24.00%
16 to 20 degrees 65 43.33%
21 to 25 degrees 21 14.00%
26 to 30 degrees 9 6.00%
> 31 degrees 4 2.67%
Voters: 150. You may not vote on this poll
Unread 10-01-2007, 22:23
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Ramp Angle Survey
Originally Posted by Don Rotolo View Post
Do you want another robot turning atop yours? I don't
That's really a moot point. From driving previous robots, I've noticed that motor stall and joystick sensitivity at low speeds is a BIG issue. Since I imagine you don't want robots climbing at high speeds, then you're going to be dealing with robots turning on your robot no matter what.
I think it a plausible sequence would be like this:
-Team is driving very slowly up skinny ramp
-Team stops to make sure orientation is good
-Team attempts to continue at low speeds, but one side un-stalls first, causing the robot to rotate. They now either have to deliberately rotate, drive off and try again, or just give up and hope they reached 4".
Which makes me realize that painted-on markings for vertical displacement of 4" and 12" on any given ramp would be a very good idea. Also, having your ramp removeable between matches would be good. Who wants a 4ft ramp above their heads if they know before their match that they'll be climbing an partner's ramp?
Keep in mind that all those holes will reduce the structural strength as well. I'm sure nobody wants to see their robot fall through a ramp...
Your ramp certainly doesn't have to be a flat piece of metal. You could probably get away with a honeycomb-like bit of metal supported by some posts, with thin carpet on top.
Unread 10-01-2007, 22:37
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
I like the info posted here, it will be very helpful to us, as we are designing a rampable bot, hopefully capable of holding two others.
Here's an idea for you all to consider- what if, instead of a flat ramp, you had a curved (or maybe even parabolic-less trouble with that leading bumper edge) ramp. l believe that this could potentially allow a shorter (in length) ramp to accommodate a longer/less ground clearance wheelbase, especially if said ramp was parabolic rather than a perfect circular curve.
Just a thought. Let me know what you think.
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Angle of Launcher ThisGuyRight Rules/Strategy 3 24-01-2006 11:05
Angle from X,Y Astronouth7303 Programming 18 19-04-2004 22:08
The angle of going up the Ramp David Bryan Programming 2 21-01-2003 20:56
