Go to Post It moves so smoothly because it is magic. - dtengineering [more]
Unread 08-01-2007, 17:31
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: I have a quistion about stopping the autonomous mode...
Originally Posted by jgannon View Post
...but don't make a habit of doing it that way. Get a dongle. Build one yourself, or order Andymark's. The competition port is not fused, and some pins are connected directly to the processor in the OI. If you touch the wrong two pins together, you may damage the OI.
That, and a dongle is a good safety mechanism to have handy. We've had more than a few "runaway bots" during autonomous testing, especially when someone disconnected the shaft encoders while adjusting wiring.
Heck, I'm tempted to make a "deadman's switch" dongle for some of our tests.
Unread 08-01-2007, 22:01
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Need I mention When Robots Attack?
Unread 08-01-2007, 22:42
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
assume the worst. include a deadmans switch on the controller, just in case. that way, if the program works, you smile!
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Unread 08-01-2007, 22:59
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
I made it a general rule that loops are NOT allowed in our code. If a loop is messed up then you have big problems on your hand. Besides why have a loop inside a loop to do the same functions a state machine can do or a timer variable
Unread 09-01-2007, 14:10
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
Ok but How can I test it at school?
Unread 09-01-2007, 16:07
Use a "dongle" on the competition port of the Operator Interface. You can enable/disable the robot, and you can switch between autonomous and teleoperated mode.
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Unread 10-01-2007, 16:07
FRC #1690
and where do i connect the "dongle"?
1 side to the Competition Port at the Operator Panel.
where to connect the other side?
Unread 10-01-2007, 21:31
There is no other side. It plugs into the OI's competition port, period.
Unread 11-01-2007, 00:21
FRC #1690
uh? what do you mean "no other side"? how deos this "dongle" looks like?
i think i found PDFs which explains more about the competition port, and it says i have to bring an On/Off switch, and to connect pin 5, 6, and 8 (on the competetion port) to the switch.
is this what you say?
Unread 11-01-2007, 07:52
One switch between pins 5 and 8 selects autonomous mode when closed, the other switch between pins 6 and 8 disables the robot when closed. The third switch on the drawing does nothing unless you're using a pre-2005 control system. http://www.ifirobotics.com/docs/comp...guide-reva.pdf tells you what you need to know.
With a DB15P connector, two SPST switches, some wire, and a box to mount the switches on, you'll be able to make a very useful tool for testing and operating your robot.
Unread 11-01-2007, 15:43
AKA: Jamie Bliss
If you don't understand what that means, hand the drawing to your Electrical mentor and ask him/her to build it.
Or go to AndyMark.biz and buy theirs.
Autonomous mode... to the max Total Meltdown Programming 16 18-01-2006 22:19
How do I enter the Autonomous mode? CompMaster Programming 5 17-02-2005 19:12
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
counting in seconds for the autonomous mode?? Pattyta Programming 22 31-03-2004 12:55
