Go to Post The people that have posted in this thread are intelligent and I know that when they talk, I need to listen. - rtfgnow [more]
Unread 07-01-2007, 11:47
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Vacum system usage
DO you guys know how the Vacum Pump works?
There's that diagream there, but where does it go further?
We are thinking uf puting this pump on our arm and usa vacum to pick up tubes..
Thanks =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 07-01-2007, 13:13
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
Re: Vacum system usage
I had the same idea. U can use a vacuum pump or pneumatic cylinders to create suction. Have one of the ports on the cylinder attatch to a suction cup. I saw a robot in 2003 that created enough suction to swing the big ball around (30" diameter, 10 lb.).
"Klaatu barada nikto!"
Unread 07-01-2007, 13:16
Tottanka's Avatar
AKA: Liron Gurvitz
hm...
i ownder is that's strong anought to pick bot sup?
Probably not, though could be neat if it did...
Unread 07-01-2007, 13:24
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Although you may be jumpy cause you think you have solved part of the challenge I ask you to think about when the tube pops in your robot's hand or something, if it will still be able to hang on to it.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 07-01-2007, 13:58
Tottanka's Avatar
AKA: Liron Gurvitz
Well then, its hard to believe that a tube will pop in a Vacummed hand, as it has no sharp edges that could damage it. Only option is if we pick up a damged tube, and on that part we are willing to take the risk.
Unread 07-01-2007, 14:04
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
That could of been us. We used a kit motor (Fisher-Price) plus a impeller (the one from a mini shop vac worked perfectly). The suction cup was a trash can lid with a non-permeable foam ring glued along the inside edge. When on the only way to pull it off was if the foam was pulled off. Having the vacuum constantly generated meant the seal didn't have to be completely leak free.
ID:	4829  Click image for larger version
Unread 11-01-2007, 09:44
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
This idea is not formulated with our investments, so this idea is not good because there are so many problems that can arise with this plan.
Unread 11-01-2007, 10:14
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
The suction cup is used with the venturi generator that is provided in the kit. Hook that between the air tanks and the suction cup but refer to official instruction for exact hook up.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 11-01-2007, 12:37
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
If you're interested in calculating vacuum pressure vs. vacuum cup size vs. lifting capacity, there's some basic info here.
Keep in mind that vacuum pickup cups are very sensitive to leaks - it doesn't take a big one to cause a loss of attachment. Also, if you use place the vacuum generator far from the cup(s), and use small-bore tubing, it will take a loooong time to attain or release vacuum out at the cup. Finally, if you have multiple cups connected to one vacuum generator, a leak at one cup will affect the others unless you play games with restrictions in the lines (which will slow down the vacuum flow even more).
My advise to anyone who hasn't used vacuum before: don't expect vacuum to behave anything like compressed air, and remember that a perfect vacuum is only 14.7 psi (and you'll never get perfection).
Pete Kieselbach
Unread 11-01-2007, 12:44
Onward through the fog.
Isn't this Oscar? Oscar was so cool.
Jane
~ Helen Keller
(1880-1968)
Unread 11-01-2007, 12:56
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
It was actually 2004. 2003 was Stack Attack. One of the Teams that did it created a vaccum pump and used an small bike tube to be the suction cup. The team was 267. When I find a picture I will post it. Couple others did it also
Hows my searching? Call 1-800-Green-Dots
Unread 11-01-2007, 23:00
AKA: Nelson Green
This remind me of a something my transport (fluid dynamic) teacher told us once. When he got out of college he went to work in St. Louis in a plant right off the Mississippi. There was a recent fire at the plant and the fire pump truck tried to use water from the river but were unable to. One of my teachers first job was to figure out what went wrong. Aparently the pump truck had tossed a hose down into the Mississippi expecting to be able to pump it up to put out the fire, but the water was 90 feet below the pump truck. Since a perfect pump could only draw 33.9 feet of water (or 760 mm Hg, 14.7 psi, etc.) the pump truck had no chance of pump 90 feet up to the fire.
Unread 12-01-2007, 00:32
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Just a note... We experimented with the suction cup, and found that it left something to be wanted. One of our mentors works with suction to some degree, and this particular cup is perfect for lifting solid object, such as a sheet of glass. We noticed that you have to make sure to press down hard on the tube to make it stick, but after that it still works fine. My only concern is how these tubes will interact with the suction cup once they have gone through a variety of matches and have had a chance to accumulate alot of dirt.
Currently, our team has split, and we are designing two lifting mechanisms, one with suction and one without. We're going to mock them up and see which one is more efficient/effective.
Duct Tape Usage anna~marie Chit-Chat 27 11-11-2006 16:36
GetPacketNumber usage Joshua Lynn Programming 1 11-02-2006 09:10
STAMP Usage Raven_Writer Programming 3 12-08-2003 08:35
Multiple files usage punarhero Programming 2 12-01-2003 11:45
Laptop Usage Goya General Forum 3 07-01-2003 08:25
