Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Unread 11-01-2007, 10:27
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: What are we supposed to do!?!?!?!??!?!
We already went through the presentation of the C and it didn't give us the real help. It told us where to go but not specifically what to do(yes, write your autonoms code. But what values, varibles, functions etc. are we supposed to use in it?).
What really helped was the the RC reference guide, thx!
Unread 11-01-2007, 10:31
AKA: Nir Levanon
Originally Posted by Bomberofdoom View Post
Autonomous Mode means that the RC will ignore all data from the Operator Interface and it will not
require a link with the Operator Interface to execute code.
If you wish to run the Robot Controller exclusively in Autonomous Mode, one way to do this is to set
your team number to zero. This is done by setting the team number on your OI to zero, linking your OI
and RC by tether, and then disconnecting from tether. After your RC is reset it will be in Autonomous
Mode.
To exit Autonomous mode if your team number is zero, you must re-tether and change the team number
to anything but zero.
An additional method for getting into Autonomous Mode is described in the Operator Interface
Reference Guide in the “Competition Control LED” section. See the Programming Reference Guide for
details on how to program for Autonomous Mod
Where is the team number value?(which source file?)
Unread 11-01-2007, 10:37
jakk jakk is offline
Jonathan Kobayashi
FRC #0368 (Kika Mana)
jakk has a spectacular aura aboutjakk has a spectacular aura about
Actually, can't you make something that will simulate the master controllers used at FIRST? You can connect some switches to that 'competition' port on the top and run either autonomous or disable the robot. Not really sure what pins but it can be done.
http://www.mckinleyrobotics.org
Unread 11-01-2007, 13:46
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Run the default code first. After loading the code into the robot controller, open the terminal, if the statement "printf(..." is not commented out, it will print the values for the joysticks. You can add other variables (like switches) to the printf. Move the sticks and see what values change. Look at Default_Routine() like the other poster said.
Look at ifi_aliases.h for the possible variables you can read and set.
Autonomous mode is in user_routines_fast.c. Look at User_Autonomous_Code(). It runs in a loop so you have to have a state machine. After you get the robot going and a few things figured out, then search around for an example or post back here.
Note: The operator interface will not talk to the robot controller until you set the team number on the IO and tether it first.
Hope this helps,
Brian
Unread 11-01-2007, 16:09
AKA: Nir Levanon
Thanks for the help guys.
I guess the only problem is right now is just trying to dycript those small macros, functions and other varibles and how they relate to the robot or OI.
But our Programming group all agreed that we've reached the begining point and we can probablly see the next step ahead(with minor help from you guys and Delphi).
Thanks again
Unread 11-01-2007, 16:19
AKA: Nir Levanon
BTW, I find the previous codes some people sent very usefull. It'll also help me and the team to get some more work to do(I'm head of the programming team{and look how desperate I was}).
Please send any previous codes you can(with comments of course, so we may understand ). We will really appreciate it.
Unread 11-01-2007, 16:25
robbekid robbekid is offline
FRC #0056
robbekid is on a distinguished road
read kevins code, he has really well documented code, i am learning the programing this year as I am planning on helping with the programming from next year on wards, so i have been working with just decoding kevins FRC code.
07 - NY, FL and ATL
Unread 12-01-2007, 16:30
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
www.kevin.org/frc
Unread 11-01-2007, 10:39
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
The team number isnt set in the code, its setting in binary using the dipswitches..
Also, just try to get a copy of someones code (i would upload mine but i dont have it with me) and just look through it and try to learn it. Before last year I didnt have a clue what a #define statement was, i just read over the code from previous years over and over again and read all the programming papers on ifirobotics.com... now i knew the controller inside and out...
Good luck
What are Potentiometers? Theory6RobotiX Control System 18 30-12-2005 09:57
PBASIC 2.5 Software supposed to be released TODAY. Travis Hoffman Programming 7 13-01-2003 20:43
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Who was supposed to be in Huntington?? Heather 45 Off-Season Events 4 16-03-2002 22:43
