Go to Post Dave: THEY'RE NOT DOLLIES THEY'RE MY FRIENDS! - Dorienne [more]
Unread 11-01-2007, 10:30
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: What are we supposed to do!?!?!?!??!?!
There is a function in user_routines.c called Default_Routine(). This is basically your playground, this function runs about 38 times a second (26.2 milliseconds) and you put all your logic in here. Your OI data (joystick values, buttons pushed) is all available in aptly named variables (p1_y, p2_x, p2_sw_trig, etc) that you can check with if statements. For example to make the trigger on the joystick connected to Port 1 drive the robot forward and your motors are on pwm01 and pwm02 you might try this:
// in Default_Routine()
	if(p1_sw_trig) // If the trigger is pushed
		pwm01 = 255; // Left motor full speed forward
		pwm02 = 0; // Right motor full reverse since it's likely facing the  opposite direction
	else // Trigger is not pushed
		pwm01 = 127; // Motor stopped;
		pwm02 = 127; // Motor stopped;
Note this is not a recommend way to drive, you're better off mapping the pwm outputs to the joystick inputs like this:
pwm01 = p1_y;
That should be enough for you to get started, it's all just basic logic.
Good luck!
Matt Krass
What are Potentiometers? Theory6RobotiX Control System 18 30-12-2005 09:57
PBASIC 2.5 Software supposed to be released TODAY. Travis Hoffman Programming 7 13-01-2003 20:43
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Who was supposed to be in Huntington?? Heather 45 Off-Season Events 4 16-03-2002 22:43
