Go to Post I would like to know the team simply because it seems they could use a hug. - Taylor [more]
Unread 09-01-2007, 16:27
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Define A Wedge
Now all this talk about ramps has me wondering. What is FIRST's idea of a wedge??? Now I went and searched the definition and it gave me a few:
-any shape that is triangular in cross section.
-something solid that is usable as an inclined plane (shaped like a V) that can be pushed between two things to separate them.
This two can be completely different in a robot sense. Now which do you think FIRST means by a "Wedge". And If you have a better definition I'd be glad if you posted it.
Thanks,
1565
Unread 09-01-2007, 16:33
Billfred's Avatar
Billfred Billfred is online now
Re: Define A Wedge
Thanks,
1565
I'll tell you exactly what FIRST means by a wedge:
<R05> "Wedge” ROBOTS are not allowed. ROBOTS must be designed so that interaction with
opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor
defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the
ground (the top of the BUMPER ZONE) that are used to push against or interact with an
opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the
ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage
(e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other
ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the
infraction.
I intend to move a ruler around our entire robot this year to see if anything below the 8.5" mark could be interpreted as such.
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Define A Wedge
the wedge rule is no longer counted when you are in the home zone and trying to lift up another robot. therefor when you deploy your ramp at the end of the match you are not breaking any rules.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 09-01-2007, 16:52
FRC #1360
Re: Define A Wedge
yeah I know that. But my design is not nessacary a ramp. So by reading this rule would on think that a platform that is between these measurements (0 - 8.5 inches) with a flat edge on it, be considered legal?
Unread 09-01-2007, 17:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Define A Wedge
They've made an excellent change to the wedge rule, from the way it appeared last year. And I'm not talking about the home zone exemption. It used to restrict parts "that might push against another robot"; now it covers parts "that are used to push against or interact with an opposing ROBOT".
Under the old rule, pretty much every robot was theoretically illegal, in some insignificant way. Now, you've got to actually wedge something to cause a violation.
Unread 10-01-2007, 08:57
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Define A Wedge
Here my interpretation. Anything in the 0” to 8.5” range the may lift an opposing robot (offensive or defensive) off of its wheels is a wedge.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 10-01-2007, 09:40
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: Define A Wedge
I would ammend that slightly. I would say that anything in the 0" to 8.5" range must be within 0-10° of vertical.
Unread 10-01-2007, 10:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Define A Wedge
I agree with Matt.
Unread 10-01-2007, 17:10
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: Define A Wedge
If your design could easily lift any part of a bot off the ground, it can't be used on the field (excluding alliance zones). It was actually last year that they added this rule. There was this huge argument thread here bout it too. I said that it counted as robot entanglement, which was an existing rule. Soooo, looks like my argument won as they expressly forbid wedge use.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 10-01-2007, 17:30
FRC #1360
Re: Define A Wedge
Ahh I see ok that helps thanks. My design cant lift robots until I want it to but it is fiarly thin. so it should be allowed.. if not there is an easy fix lol
Unread 10-01-2007, 18:00
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Re: Define A Wedge
What if i have a wedge but i cover about 5 inches with lets say polycarb would it be considered legal u think?
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 11-01-2007, 11:14
REVving up for a new season
FRC #2848 (All-sparks)
Re: Define A Wedge
I am trying to figure out if this counts for inverse wedges also, like an angled section to make it easier to climb robots. see drawing below...
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-01-2007, 11:21
AKA: Matt
Re: Define A Wedge
The way it is currently written, I am afraid the answer is yes, that would be illegal based on the wedge rule. This is an unfortunate oversight that did not seem to get corrected from last years rule.
Matt B.
Unread 11-01-2007, 11:22
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Re: Define A Wedge
The quick answer is YES this is a wedge. It looks to be greater than +/- 10 degrees of vertical.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 11-01-2007, 11:41
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: Define A Wedge
Almost every year we put wheelie bars on our robot and we have to modify them to make sure they dont get us penalized. A blatant wedge that is on your robot, or something that isnt designed to prevent robots would be considered a wedge imo.
Min-Max to the Max!
Define FIRST slickguy2007 General Forum 24 13-10-2006 08:24
#define creation NASAbound1636 Programming 3 02-02-2006 23:40
#define and #ifdef/endif DanDon Programming 12 29-04-2005 19:27
Conditional #define Statements Ian W. Programming 3 14-02-2004 18:14
Wedge bot DQ fsracer General Forum 24 27-03-2003 18:38
