Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2007, 11:27
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
AM KoP Wheel Slant
I have noticed that the AM wheel included in the KoP has a slant to the tread. The slant seems to be a design feature rather than a manufacturing defect since it is clearly on the prints here. In other words, the slant is intentional and thus must have a purpose. My question is what is it? Also, what it the intended orientation of the slant with respect to the drivetrain (i.e. slant in or out)?
Unread 11-01-2007, 11:36
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: AM KoP Wheel Slant
Hi,
That is probably draft from the molding process (slant designed in so that the mold can release). I would expect that it would wear down pretty quicly and flatten out after some use. It probably doesn't matter which way you set it up.
RAZ
Unread 11-01-2007, 11:42
Ahh! I wasn't thinking about the need for the slant in the manufaturing process. Yep, I bet that's it. Thanks! Maybe Andy will chime in here and confirm.
Unread 11-01-2007, 12:25
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
That is the case per a conversation I had with Andy (Mark actually did the design work) at the Kick Off workshops. The slant was needed to release the mold. You'll notice a little "cup" also. Not to worry, it'll wear down and become flat pretty quick.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 11-01-2007, 14:00
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Yep... what Dana said. The mold was cheaper if the part was designed this way.
AB
Unread 11-01-2007, 14:24
Thanks for clearing this up guys. I was trying to figure out what advantage the slant would have one way or the other and just didn't see the advantage. It all makes sense now.
Also, Andy and Mark, thank you for providing such a great wheel in this years KoP! It sure beats the old Skyways! Kudos to you guys!
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
KOP wheel model? Cody Carey Kit & Additional Hardware 4 10-01-2007 23:26
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
