Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2007, 10:57
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Pillow Block Bearings
Where do you guys get your pillow block bearings?
Unread 11-01-2007, 11:07
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
Re: Pillow Block Bearings
Depending on your use igus might be good for things. Their a lot lighter but are weaker. I dont recomend you use them for drive but places away from direct contact are were these pieces shine.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 11-01-2007, 11:26
DavidGitz's Avatar
How about pillow block bearings for main drive components? I'd like cast iron, sealed (no zerks), bearings already put in that accepts 1/2" keyed shaft.
Unread 11-01-2007, 11:38
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
If you are using the banebots gearboxes (the ones that came in the kit of parts), they sell 1/2" bearings. http://www.banebots.com/pc/FIRST/PB-S5002-BB
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 11-01-2007, 11:54
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If I were the King of FIRST, these bearing blocks would have been in the kit.
If your sprocket is going to be near the bearings, you can probably get away without supporting the Banebot 56mm transmission gearbox but why risk it?
The bearing block is $12.50. Use it. You'll sleep better at nights.
Joe J.
Team #88, TJ2
Unread 11-01-2007, 12:08
DavidGitz's Avatar
I agree, the pillow block bearings have been included in the past. Oh well.
Unread 11-01-2007, 12:10
Starman Starman is offline
Starman will become famous soon enough
Pillow block bearings may also be purchased from W. W. Grainger, McMaster Carr, or Stock Drive Products. Check them out on the web. You may have a Grainger Dealer close by.
Pillow Block from KOP 2004 Don Wright Technical Discussion 2 23-01-2005 17:21
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
pillow blocks Jacqui Sutton Kit & Additional Hardware 1 11-01-2003 10:43
Pillow block Greg Needel Technical Discussion 4 01-02-2002 15:18
