Go to Post Patience is a good strategy. - Koko Ed [more]
Unread 11-01-2007, 12:06
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Re: Define A Wedge
Inverse wedges will help climb. Should not be allowed according to the rules though. But last year, I know a couple team who followed the 12 feet per second rule and some that did not. It wasn't fair but people still did it. Same thing will happen this year with these type of machines. People will make them and inspectors will not see a problem.
Like Aquidneck Island Robotics on Facebook!
Unread 11-01-2007, 13:41
Drew's Avatar
Drew Drew is offline
Drew
FRC #0302 (Dragons)
Team Role: Animator
Drew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the rough
Send a message via AIM to Drew
Re: Define A Wedge
Ok a wedge... Anything that Team 302 does not create is not a wedge. In previous years at least. The wedge rule was made because of team 302. We kept getting penalties because other robots would drive up our wedge and tip over. they kept calling it a wedge and Lift but we never did the and lift so just make sure the wedge is 10 degrees or less
Unread 11-01-2007, 21:21
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: Define A Wedge
Originally Posted by ttedrow View Post
The quick answer is YES this is a wedge. It looks to be greater than +/- 10 degrees of vertical.
Technically, it is a wedge. Think about this: you could drive on top of an enemy robot (un/intentionally) and smash their control board.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 11-01-2007, 21:22
Re: Define A Wedge
If you were seeing a problem, then report it and don't complain about it later. At our event, they speed tested EVERY lancher at full speed.
Define FIRST slickguy2007 General Forum 24 13-10-2006 08:24
#define creation NASAbound1636 Programming 3 02-02-2006 23:40
#define and #ifdef/endif DanDon Programming 12 29-04-2005 19:27
Conditional #define Statements Ian W. Programming 3 14-02-2004 18:14
Wedge bot DQ fsracer General Forum 24 27-03-2003 18:38
