Go to Post ...these guys have taken it to a new level. (I want to be part of a team like that.) - Tetraman [more]
  #46   Spotlight this post!
Unread 10-01-2007, 19:49
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: 2007 Default Code?
Originally Posted by Mike Copioli View Post
MPLINK 4.02, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - Coff file format for 'C:\First2007\Code\frc_camera_s_2\camera.o' is out of date.
Errors : 1
Now I get his error????
Our you sure you have the correct version of the compiler? I think that might be your issue.
  #47   Spotlight this post!
Unread 10-01-2007, 20:00
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
I figured it out. I have both the student version and the full version of the compiler. I set the exe to the proper directory but not th lib and linker. Once I set all to the correct directory, the code compiled.
Thanks
  #48   Spotlight this post!
Unread 10-01-2007, 20:38
nheft nheft is offline
FTC #0533 (Psichotics)
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
It's at http://ifirobotics.com/rc.shtml#Programming. Look towards the bottom of the page.
  #49   Spotlight this post!
Unread 11-01-2007, 11:40
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Thanks for the link!!!
A few of questions related to the default code….
I just downloaded the IFI site default code.
Is it ok to use this basic code and modify it as we need to?
Also is this code (or any code for that matter) already loaded
into the user and robot controllers?
What all does the default code do?
Does it include any routines for spinning the drive wheel motors when the joystick control is changed?
  #50   Spotlight this post!
Unread 11-01-2007, 13:45
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Can anyone tell me what I am supposed to do with the Frc_Master_V13.bin file? I downloaded the 2007 code and I see it there, but it's not in the MPLAB project. I looked at the code that the team was running last year, and it is not even in the project directory.
Any help in this matter would be greatly appreciated.
  #51   Spotlight this post!
Unread 11-01-2007, 14:06
You download the new Master file to the Robot Controller just like you do your program .hex file.
-- Tether the OI and RC and power them up, put the RC into program mode.
-- Click Browse in IFI_Loader, then in the file selection window change the file type to ".bin" and you should see the new Master.bin file in the directory to select and download.
-- You must follow up by downloading your .hex file or the default .hex file.
Here are some detailed instructions from IFI.
  #52   Spotlight this post!
Frc_Master_V13.bin is the code for the Robot Controller's master processor. It gets downloaded it to the RC using the same IFILoader program that puts code in the user processor. The RC should already contain it, but in certain cases you might have a need to reload it.
Any teams planning to use a Robot Controller from a previous year for practice or prototyping will want to put the V13 master code in the system (in order to talk to the new radio modems, I believe).
  #53   Spotlight this post!
Unread 11-01-2007, 14:27
FRC #1094
"Excellent" - Montgomery Burns.
Thank you very much for the information, it was very helpful.
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
default code archiver 2001 2 23-06-2002 22:53
