Go to Post Its a good bug too. :) - spadercool [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2007, 13:27
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
Talking sprockets
does any one know where to get the following parts. Wheel sprocket,24 tooth/drive train bag#35,1.25 bore,1/4 hub # 10 mntg holes in a 1.875" D circle
Also does any one know where to get a Output sprocket-Drive train bag 1/5" bore,1/8" keyway
Unread 10-01-2007, 14:06
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
Re: sprockets
Great places such as msc or mcmaster exist to provide such things. http://www.mscdirect.com/ and http://www.mcmaster.com/. You'll be able to find a multitude of parts such as sprockets and shaft, as well as many other things.
Unread 10-01-2007, 14:18
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: sprockets
Check out Andymark.biz as they are the source for some of the KOP components. IFI Robotics also sells similar components.
BEN
Unread 10-01-2007, 20:39
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: sprockets
The similar Aluminum IFI/AndyMark sprockets have the same bolt pattern for the KOP wheels, but the smallest is a 28t I believe.
If you order a 24t sprocket from McMaster, you would have to drill the mounting holes yourself.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 10-01-2007, 21:30
Kilroy0846 Kilroy0846 is offline
FRC #2139
Kilroy0846 is an unknown quantity at this point
Re: sprockets
My team is looking for simmilar parts.
My question is: How would you order duplicate parts of the ones that come in the kit?
Unread 10-01-2007, 21:45
Gurdian Gurdian is offline
Lord Protector
AKA: Ryan Fender
FRC #1730 (Team Driven)
Gurdian will become famous soon enough
Send a message via MSN to Gurdian Send a message via Yahoo to Gurdian
Re: sprockets
I don't know officially for the sprockets. Most of the rest come from IFI. I saw a distributor's list but currently can't find it.
Grainger had a duplicate output sprocket (make sure you look for a 1/2 in bore, there is a typo on the kit of parts list). McMaster Carr's didn't have a keyway. As for the sprocket bolted to the wheel, I'd go with an Andy Mark.
Nuts
-Gen. McAuliffe, Winter 1944
Unread 10-01-2007, 22:11
FRC #2139
Re: sprockets
Ok doing a little more research, and with the help of Gurdian's advice i was able to come up with these
For the input sprocket that comes off of the planetary gearbox:
Sprocket 15 tooth; 35 Chain
MSC
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=16269339
Grainger
http://www.grainger.com/Grainger/wwg...mId=1611578574
And the Sprocket that is bolted to the wheels:
#35 chain, 1.25” bore, 1/4” hub, #10 mntg
holes in a 1.875” D circle
MSC
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=16269485
This one will need holes drilled in it.
Unread 11-01-2007, 14:08
Mechanical/Driver
Re: sprockets
IMO, I think it would just be easier to get the IFI/AndyMark Aluminum sprockets.
1) It's lighter
2) It bolts right up to the KOP/AndyMark and IFI Traction wheels.
The only problem is the smallest is 28t, the ones in the kit are 24t. Since you increased the tooth counting by 4, then do the same for the smaller one, so get a bigger one for the shaft. Or you can just get a custom better geardown for your own situation (more torque, more speed).
Unread 12-01-2007, 08:30
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: sprockets
They have 24 teeth now too.
Sprockets laney836 Chit-Chat 3 02-11-2005 19:46
45 tooth sprockets maxgebhardt General Forum 1 26-01-2004 22:45
Sprockets VinceT Kit & Additional Hardware 4 18-01-2004 23:07
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
sprockets Greg Needel Technical Discussion 0 23-04-2002 12:30
