Go to Post Understand that not only can you learn from other experienced engineers, but also mechanics, farmers, and craftsmen. - Andy Baker [more]
Unread 10-01-2007, 09:30
Shomron1690 Shomron1690 is offline
FRC #1690
Shomron1690 is an unknown quantity at this point
Searching the new gear motor PDF
Hello all,
We've search for the instructions - how to build the new gear motor.
We will be glad to see some comments,
Thanks,
Team #1690
Unread 10-01-2007, 10:10
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Searching the new gear motor PDF
Could you please be a little more specific as to which gearbox (or motor?) you are refering to?
All of the motor data can be found on the FIRST website, under the "Tips and Good Practices" document.
Information on the Banebot planetary transmissions can be found on the Banebots.com website.
BEN
Unread 11-01-2007, 10:24
FRC #1690
we got in the kits new gear (not like the last year)
we didn't find any PDF or outher instructions how to connect between the gear box and the CIM motor.
what we are asking if somone have a PDF that describe how to implement this thing.
tnx
Unread 11-01-2007, 16:00
Bengineer
Instructions for mounting the small (2.5") CIM motor to the 56mm Banebot gearbox can be found in the cardboard box that the gearbox is packed in. If that has been lost already, you can probably get Banebot.com to email you the instructions. (Or, if someone here wants to scan it and send it. I don't have it here in front of me.)
Good luck,
BEN
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
Specs on the gear of the fisher price motor archiver 2000 0 23-06-2002 23:23
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
Gear for the black motor Kirk Motors 5 11-01-2002 15:15
