Go to Post Remember that the reason that you do something should NEVER be for the sole purpose of winning an award. To paraphrase something said by one of the Hall of Fame teams: "You should choose to do something because it is fun and the right thing to do." - tim-tim [more]
Unread 11-01-2007, 17:26
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
2007 demo code not working
My team attempted to upload the 2007 demo code for the camera an it did not work.
Is there something special we need to do?
I had it in autonomous mode and the camera was on it reconized the light but did not move
-Dustin Benedict
Unread 11-01-2007, 17:50
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: 2007 demo code not working
Make sure your robot is in autonomous mode. It doesn't call the camera code in operator control.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 11-01-2007, 23:08
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Were the servo's plugged into PWM's 10 and 11?
Hit F6 it will show you the defines for the camera servo and tilt PWM ports.
Then you can change them to what ever you want. Also when the terminal
window is open make sure you check off "graphics display"
Unread 12-01-2007, 20:07
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
The default pwms (at least in the default codes I have seen) are PAN_SERVO = pwm01 & TILT_SERVO = pwm02. The PAN_SERVO and TILT_SERVO macros are defined in tracking.h.
Unread 12-01-2007, 23:43
Kingofl337's Avatar
AKA: Adam
And your trying to get it to work in easyC?
If your using easyC I recommend you try this first.
http://www.intelitekdownloads.com/ea..._2007_demo.zip
It sounds like your trying to get Kevin's code to work in easyC. Which isn't a big deal I just want to make sure your not confused.
CMUCam2 Demo - File Not Found Error TechnoDrake LabView and Data Acquisition 6 12-01-2007 15:56
CMUcam2 demo.llb for 2007 Superschill Programming 3 12-01-2007 10:00
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
