Go to Post WHAT!?!?!? YOU DON'T DEVOTE YOUR LIFE TO APPLE!?!?!?!? ;) :p - Joe Matt [more]
Unread 11-01-2007, 17:27
Inverted Inverted is offline
AKA: Eric P.
FRC #1228 (Robo Tribe)
Inverted is an unknown quantity at this point
Send a message via AIM to Inverted
Custom Joystick Setup in easyC
Last year I developed a "Halo drive" control system for the robot in MPLab, which we plan to use again this year. The only problem is, since this is my senior year, I need to train some younger members to program, which will be done in easyC. Last year I completely avoided easyC because I didn't want to take the time to learn a new program. So this year I'm kinda screwed.
So anyway, I don't have the code I made up last year on me right now, as it's on my other laptop, but I was just wondering if there's any way to set up a control scheme that's not Arcade or Tank drive. If it helps, I had the controllers set up so that the wheels moved forward/back via input from the left joystick Y-axis, and moved left/right via the right joystick X-axis.
Thanks
Unread 11-01-2007, 17:50
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Custom Joystick Setup in easyC
Yes, you can use OIToPWM() for direct drive or use GetOIAInput() with SetPWM() and make adjustments.
void OIToPWM(port, axis, pwm, direction)
port - the joystick's port on the OI
pwm - pwm output port number
axis - 1 = x, 2 = y, 3 = wheel, 4 = aux
direction - 0 = normal, 1 = invert
unsigned char GetOIAInput(port, axis)
void SetPWM(pwm, value)
value - the value to set it at
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 11-01-2007, 23:12
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Check this out: http://www.chiefdelphi.com/forums/at...8&d=1165872883
It has examples of exactly what you want to do.
CMU CAM setup stephenthe1 Programming 0 17-01-2006 11:36
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
Favorite Joystick Setup? We're new eatthafoodtina Control System 22 29-01-2005 18:14
