Go to Post Never underestimate the power of curious and impatient FIRSTers ;) - kpugh [more]
Unread 11-01-2007, 20:09
predator_hunter predator_hunter is offline
FRC #0537
predator_hunter is an unknown quantity at this point
Arm Extension Question
If we were to have an arm that would be mechanically able to extend out of the 72" by 72" footprint, but it is securely limited with code, would we pass inspection? Would the inpector say that since we are able to extend out of the floorplan, even though we dont, that we are in violation?
Thanks in Advance,
Team 537
Unread 11-01-2007, 20:12
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
Re: Arm Extension Question
no, u would pass the inspection because of the fact that u are under maximun hight at the start, and once the match starts you would be able to go over hight, so good luck to you with that hight, the only thing is you would have a lower weight maximum
Unread 11-01-2007, 20:14
FRC #0537
No, there is no height maximum, and we will be starting under 4', we were questioning the length and width restrictions.
Unread 11-01-2007, 20:43
Bharat Nain's Avatar
Most likely you will pass inspection. Appropriate penalty will be given if you extend beyond 72" on the field, outside the home zone.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 11-01-2007, 20:44
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Length and width wise, you would be fine as long as you don't go out of the 72x72 footprint, like you said. Height wise, the roof is the limit (it actually says that in the rules )
-Nick 1334
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 11-01-2007, 20:49
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Please refer to the official FIRST Forums for an answer on this question.
<R12> Response
Unread 11-01-2007, 21:10
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Just make sure your constraint code is accurate because the refs. will penalize you.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Extension Mechanism acer_7 Technical Discussion 31 09-06-2006 18:02
pic: 1625 full extension Aren_Hill Robot Showcase 15 07-12-2005 23:12
Extension lift mechanics Steve Compton Technical Discussion 8 25-01-2005 15:47
What File Extension Are You? Joe Matt Chit-Chat 42 27-10-2004 07:07
