Go to Post When I'm hiring an intern "Award Winning VRC Notebook" isn't applicable. But "Award winning technical documentation" sure is. - Andrew Schreiber [more]
Unread 11-01-2007, 20:55
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Air Compressor Wireing question
Is it in the rules that you MUST use a spike relay to turn the compressor on and off? or can you wire it to be always ON and shut off using the supplied pressure switch?
- Bochek
Unread 11-01-2007, 20:59
Nate Laverdure's Avatar
FRC #2363
Re: Air Compressor Wireing question
The pressure switch is not rated to 12 volts, so it must be wired through the robot controller.
<R103> The Nason pressure switch must be connected to the output end of one of the Clippard
tanks to sense the tank’s pressure. The two wires from the pressure switch must be
connected directly to a digital input and ground terminal on the Robot Controller, and the
controller must be programmed to sense the state of the switch and operate the relay
module that powers the compressor
. The Parker pressure vent valve must be connected to
a Clippard tank such that, when manually operated, it will vent to the atmosphere to relieve
any stored pressure. The valve must be placed on the ROBOT so that it is visible and
accessible.
Unread 11-01-2007, 21:03
Bochek's Avatar
AKA: Adam Bochek
oops, well its worked so far :S
Unread 11-01-2007, 21:07
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Here is how you fix your problem, on your controls at the player station you put a switch to turn on (and off) your compressor, then you turn it on at the start of the match and leave it on for the rest of the match, the air regulator will turn the compressor off automatically when you've reached the maximum allowable pressure.
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Yes, you must use a spike relay to control the compressor via the pressure switch.
The default code from IFI has the pressure switch wired to Digital I/O 18, and the compressor on/off to relay_8.
digital_io_18 = INPUT; /* Used for pneumatic pressure switch. */
relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 11-01-2007, 21:16
Bochek's Avatar
AKA: Adam Bochek
what is to stop us from wireing it up like this:
Fuseblock -> pump + -> pump -> pump - -> pressure switch -> Ground?
as soon as you plug in the battery your tanks will come up to pressure and the pump will shut off.
- Bochek
Unread 11-01-2007, 21:18
Bochek's Avatar
AKA: Adam Bochek
OOPS, just realized you posted <R103> and i just read it.
My bad, OK, looks like thats the way to do it then.
- Bochek
Unread 11-01-2007, 21:34
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
This is something that I have been tempted to do in the past, but if you take another look at <R103>, I think that may not be kosher.
Originally Posted by R103
The two wires from the pressure switch must be connected directly to a digital input and ground terminal on the Robot Controller, and the controller must be programmed to sense the state of the switch and operate the relay module that powers the compressor.
The word "must" indicates to me that you are not allowed to just rely on the regulator.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
Looking for Air compressor part SteveC116 Inventor 3 01-02-2003 20:53
compressor and light question... archiver 2001 5 24-06-2002 00:47
Air Compressor geo Technical Discussion 4 06-02-2002 22:52
