Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 11-01-2007, 21:48
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: the frame
http://www.ifirobotics.com/docs/chas...y-12-14-06.pdf <-- construction instructions.
I would just like to add. if you are just getting around to building the frame now.... HURRY UP!!!!! we only got 5 weeks left!!!!
Unread 11-01-2007, 22:16
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: the frame
The kitbot is very easy to assemble. Just remember to cut it down to 28"x38"...either a wide or long config. Also replace the nuts with better ones because if you dont you will lose a ton of screws at the competition.
As far as time goes, you've got 5 weeks left....get that chassis together! One of the advantages the kitbot gives you is its all there and easy to build...giving you a moving bot faster than some teams with a custom chassis. This gives you more time to work on your manipulators and test it out.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-01-2007, 22:23
Endenil Endenil is offline
FRC #1339
Endenil is an unknown quantity at this point
Re: the frame
Would cutting it down to 21 by 31 for standard bumpers be good/work?
Unread 11-01-2007, 22:36
Mechanical/Driver
Re: the frame
Yes, but remember, you can have your chassis up to 28"x38" without bumpers and still pass. The bumpers aren't included in the area and weight of your bot.
Unread 11-01-2007, 22:37
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: the frame
Only cutting the frame down to 26 by 36 or whatever you see fit will be nessary. You dont want to make it 28 by 38 exactly because we did made our robot right up to the deninsions and we had to take out some screws to make it fit in the box. Standard bumpers can extend outside of the deminsions and can weigh up to 15 extra pounds.
<R37> Teams are strongly encouraged to use bumpers on their ROBOTS. Bumpers can reduce
damage to ROBOTS when they contact another ROBOT or field elements. Teams may
choose to use STANDARD BUMPERS or custom bumper designs. STANDARD
BUMPERS have several advantages, such as being excluded from the calculation of the
ROBOT weight and volume limitations specified in Rule <R07>. TEAMS that choose to use
STANDARD BUMPERS, will have both a more robust ROBOT and the traction advantage
of a heavier ROBOT. Alternately, TEAMS may develop custom bumper designs for use on
their ROBOTS. However, custom bumper designs are NOT eligible for the weight/volume
exclusion offered for STANDARD BUMPERS. All custom bumper designs are considered
part of the ROBOT, and must satisfy the constraints listed in Rule <R07> (as well as all
other rules). STANDARD BUMPERS must be designed as described below. Any bumper
design inconsistent with these design elements will be considered a custom bumper.
Note: This is not the full rule.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 11-01-2007, 22:38
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: the frame
If you are using the FIRST design (and recommended) bumpers, then they do NOT fall under the robot sizing and weight constraints. However, they do have to follow (exactly) the dimensions and construction method spelled out in the manual. FIRST also limits the weight of the bumpers to 15lbs. Though, I don't think there was a single team last year that violated the weight rule, as the construction method can't really reach that weight.
Therefore, I would suggest cutting the kitbot frame down to 37"x27". This will give you an extra inch of clearance, in case you have bolt heads, gears, or whatever sticking out a little further than you expected.
Good Luck!
BEN
pic: the start of our Extruded fiberglass frame falconmaster Extra Discussion 8 09-01-2007 08:54
Why didn't your team use the Kitbot frame in 2006? Billfred Kit & Additional Hardware 33 31-05-2006 00:00
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Frame Dragging Wetzel Math and Science 0 22-10-2004 17:10
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
