Go to Post The jags are powered with magic... - Aren Siekmeier [more]
View Poll Results: How Much weight for electronics?
<5 lbs 0 0%
5-7 lbs 11 30.56%
7-10 lbs 7 19.44%
10-12 lbs 7 19.44%
12-15 lbs 6 16.67%
15-20 lbs 4 11.11%
20+ lbs 1 2.78%
Voters: 36. You may not vote on this poll
Unread 11-01-2007, 21:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
How much weight for Electronics?
The Question is fairly simple, how much weight is set aside for your electronics usually(excluding motors)
Also not in the pole, how much space usually?
KK4KQO
http://voltair.us
Unread 11-01-2007, 22:07
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Re: How much weight for Electronics?
We are setting aside 18 pounds for everthing wiring related this year.
Unread 11-01-2007, 22:20
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
I think that the engineer who tracks our weight sets aside 20lbs for our controls. I doubt we're that heavy, and I think it's more like 10ish lbs. We should weigh it this year.
As far as space goes, for the past several years (from what I've seen of old bots) T3 has used a piece of plexiglass, about 3ft by 2ft (don't quote me here, I'm not good at estimating things--I'm a programmer, not a mechanical guy) with the highest part extending maybe 6 inches above the plexiglass. Last year's was taller than that, I think, because we made a stand to hold the RC directly above the breaker panel, adding height.
JBot
Aren't signatures a bit outdated?
Unread 11-01-2007, 22:24
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Last year our electrical system weighed about 12 lb. We used 10 Victors, no Spikes, and the 2005 IFI breaker panel. This year I expect a slightly heavier electrical system because that panel is not allowed.
Richard Wallace
since 2003
Unread 11-01-2007, 22:55
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
I'd budget for 20 pounds and hope for better... Wire weight adds up quick.
As a side note, for those who find themselves overweight, this is an area where a lot of wieght can be removed. Removing excess wiring is quite a bit easier than speed holes!
2010-? - AIR Strike (Team #78)
2007-2009- Rhode Warriors (Team #121)
2003 - Team #190
1997-2002 - Bobcat Robotics (Team #177)
http://www.tomschindler.net
http://www.drivexc.com
Unread 12-01-2007, 12:05
Weight and size raised for the DIN mounting and Maxi block.
How much do you pay for airfare? BobC Championship Event 20 17-12-2006 14:54
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
how much over weight Nitroxextreme General Forum 39 22-02-2005 22:23
How much did YOU Pay for the tubs? yangotang Kit & Additional Hardware 6 14-01-2003 19:44
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
