Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 11-01-2007, 22:42
Ar3a51's Avatar
Ar3a51 Ar3a51 is offline
Math will solve everything
AKA: Sean Mawn
FRC #1875 (Autonomato Atonamatons)
Ar3a51 is an unknown quantity at this point
Just a question
Hi guys, im on Team 1875 and I had a weird thought about easyC. Is there a way to make/create a program on easyC then convert it into actual C code(as opposed to the blocks that you use with easyC)? I havent much experience with easyC, and I was just wondering if anyone with more experience knew how to do it (if its possible).
Thanks in advance!
Unread 12-01-2007, 00:22
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Just a question
Thanks in advance!
EasyC utilizes the WPILib library of FRC functions. I believe (at least in the new easyC Pro) there is a panel on the right side that shows you the WPILib-based code.
http://www.mikesorrenti.com/
Unread 12-01-2007, 01:04
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Just a question
Select project view tab, select the function entry under "block diagram" you want to convert, right click on the entry and at the bottom of the menu is "Convert to C". It converts the block of easyc into a regular C file.
Bud
Unread 12-01-2007, 17:02
Ar3a51's Avatar
AKA: Sean Mawn
Re: Just a question
Awesome, thanks guys. The interface of easyC is new to me, looks funny.
just wondering.... tiffany34990 Chit-Chat 6 25-07-2004 14:46
Just A Quick Question Mike371 General Forum 4 25-03-2003 14:25
Is it just me? Pin Man Televised Robotics 1 23-02-2003 20:43
Just a little question... Keys Programming 8 30-10-2002 14:50
Is it just me.... Andrew Rudolph Chit-Chat 12 17-08-2001 16:15
