Go to Post However, I am a firm believer in the theory that if you are pushing with a mecanum wheeled robot you are doing it wrong. - Andrew Schreiber [more]
Unread 12-01-2007, 00:39
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Quick question regarding the gear tooth sensor...
I've checked in the sensor manual, and understand how it works, I'm just not sure where exactly I should mount the chip, if it matters how close it is to the gear or what.
Also if any special type of gears are best? If someone could show me a few pictures and/or help me out a little with it, it would be greatly appreciated.
Unread 12-01-2007, 00:56
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Quick question regarding the gear tooth sensor...
From what we have played with, we have detected a signal from about a half inch away from the gear. the best advice i can give you is to mount it as close as possible while still allowing some shake room.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 12-01-2007, 01:03
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
From the datasheet on the sensor from the manufactures website:
http://www.allegromicro.com/datafile/0642.pdf See page 4.
Operational Air Gap Range AG DC within specification 0.5 – 2.75 mm
From the FRC 2007 Sensor Manual
A ferrous metal rotating gear (or sprocket, etc)
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 12-01-2007, 01:07
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Last year we had good luck with keeping the sensors 2 to 4mm from our metal slotted encoders. As far as gears go I think you may have even more range. If you can hook an oscilloscope to the output it makes it very easy when things are too far away. As far as how many teeth, it depends on what you are trying to measure in the final analysis. There is a practical limit on how many pulses your program will handle. The closer to the motor when you are using reduction the more pulses you get. If you are using this in the drive train. Work backward from how accurate your tracking of the bots movement do you think you need. I.e. one inch or do you need better like 1/4". Then work the numbers back to the tooth counter.
Biff
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
