Go to Post You valuable advice has prevented me from killing myself and others numerous times =) - Stephen Kowski [more]
Unread 12-01-2007, 06:21
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: I have a BIG problem with my controller, need help.
Originally Posted by razer View Post
ill try it today, thanks, but i need to connect it to the teather only once right? all the other times ill be able to use radio?
Once you have set the team number and tethered for a few seconds, you should be able to unplug the tether and use radio.
JBot
EDIT: Please consider building yourself a competition jumper. The guide to do so is in PDF format under "Competition port pinout" on this site: http://ifirobotics.com/oi.shtml
This will save your bacon when debugging and in the pit--if you want to keep your 'bot from taking fingers off, you can flick the "Disable" switch and go ahead with whatever work you were going to do.
Unless, of course, you suffer from the 8.2/8.3 volt freeze. http://www.chiefdelphi.com/forums/sh...ht=8.2+voltage
Aren't signatures a bit outdated?
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
BIG Problem, please help me!! Srkasner FIRST Tech Challenge 2 11-01-2006 12:45
BIG PNUEMATIC PROBLEM NEED HELP PLEASE!!!! archiver 2001 1 24-06-2002 00:30
Need help with controller Devil's Kid Technical Discussion 6 20-01-2002 21:47
