Go to Post There's more elegant ways to play defense than beating on the other robot. - Bill Moore [more]
Unread 12-01-2007, 10:14
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: USB Chicklet
Originally Posted by SleeveofWizard View Post
Is it possible to use more than one controller when using the USB Chicklet? If so do you need two USB Chicklets or can you use a splitter to separate the one USB port?
http://www.chiefdelphi.com/forums/sh...hlight=usb+hub
and specifically:
Re: USB Joystick adapter is here!
Originally Posted by Michael Hill View Post
Is it possible to run multiple joysticks through a USB hub using only one unit?
The Chicklet only supports HID. It does not support HUB. We have a solution that does support HUB and other device classes however that solution was not cost effective. We wanted to keep the device affordable for FIRST Teams. Also the 15-pin joystick port does not provide enough interface to support more than one device. We have a device that outputs RS232 data instead of analog/digital. It is less expensive than the chicklet. If we had a serial port on the O/I this would have been the way to go.
Mike Copioli
CTRE
team 217
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 17-02-2008 12:43
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
USB I/O CJO Control System 2 15-10-2005 20:17
usb to db15 663.keith Technical Discussion 21 20-01-2005 15:16
USB to Serial Jack Programming 24 23-12-2002 14:21
