Go to Post We have donut eating contests to see who has the best legs. We paint our pigs. We argue about which time zone we are in. About 400,000 of us gather together to watch cars go around in a circle. We also build robots.Yep, our cultural norm is a bit different. - Andy Baker [more]
Unread 12-01-2007, 11:12
StashZabriski's Avatar
StashZabriski StashZabriski is offline
FRC #3320 (Miracles & Machines)
StashZabriski is on a distinguished road
Lifting after power is cut
Is it possible (rules wise) to mechanically lift the robots after power is cut?
My team is talking about starting the action in the last couple seconds of the match and allow the robot to do its thing to lift an alliance's robot 4" or even 12" into the air after the final buzzer.
I keep wanting to say it's against the spirit of FIRST and as a veteran ref I wouldn't allow it to consistantly happen, the only problem is that I can't find a rule to back what my gut is telling me.
If there was under an inch to lift after power, that's one thing, but the team is talking about lifting a significant distance after the match because things are normally scored when the field comes to rest (trying to work around the rules).
Easiest way to show this is a counterweight like in the FLL challenge this year (not feasable, but there's other ways). Release the counterweight with 2seconds left in the game and in 4-5seconds AFTER the power is cut, the robot would end up at its final height of what ever the team wants.
Any thoughts would be appreciated so I can pass this on to the team.
~Stash~
No hunter of the sky should end his days as prey. Better to die on the wing than pinned to the ground. (Eragon by Christopher Paolini)
Unread 12-01-2007, 11:16
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Lifting after power is cut
If you have a spring system with a pneumatic dampening piston lifting a table, and release a latch to raise it in the last two seconds, It will continue to lift robots after the buzzer,.Since they wait for the field to "settle", it should count as points for you.
Unread 12-01-2007, 11:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll agree with Cody. The score after things settle, so I don't really see a problem. I think it would be a problem if the mechanism was rigged to release and start lifting as the robot loses power and the match ends, however. I think at tha point the match is over and you're having your robot start things after the match. Obviously a Q&A question, though. Practically speaking, I don't really see a feasible way to manage this without massive counterweights or some pretty big springs, so I'd be curious to see how you managed it.
Unread 12-01-2007, 11:23
BillP's Avatar
BillP BillP is offline
AKA: GreenBeard
None #0624 (CRyptonite)
BillP is a jewel in the roughBillP is a jewel in the roughBillP is a jewel in the rough
It's probably a little complicated on the construction side, but with respect to the rules, it would probably be OK. As previously stated, the scores are not calculated until the field comes to rest.
Turning this backwards, in previous years, we were required to remain hanging from a bar after the match was over. If the robot was slowly creeping down towards the ground, the ref's would wait until it either stopped its decent or touched the ground. This is exactly the same idea, just in reverse.
Of course, to get the answer that really matters, you should submit the question to the Q/A forum.
Good luck.
Unread 12-01-2007, 11:25
REVving up for a new season
FRC #2848 (All-sparks)
I can tell you right now that we are planning on something like this. Pneumatics can be set to fire when the robot goes into disable mode. Alot of teams did things like this in 2005 to drop a tetra at the end of the mach. The way we look at it the match always ends when things come to rest. and a pneumatic shot only takes a couple seconds. In my mind this is the same as last year when balls were shot at the end of the round based on momentum of a wheel and counted or teams were climbing the ramp and their enegery carried them to the bonus.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 12-01-2007, 11:29
Thanks for the quick replies!
I've been a ref for a few years and I remember the hanging bar. I was one of the refs in charge of deciding who was hanging after the end. I was looking at things in that respect but I was also looking at it in reverse. If they started to pull up and the buzzer went off, would it be counted if they were able to keep pulling themselves up after power was cut?
Once I get the ability to post on the Q&A I'll put this there. Either that or I'll see if I can get ahold of the team's login info to post though their username.
~Stash~
Unread 12-01-2007, 11:31
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The match is scored after the robots and elements come to a rest. Teams that hung on the bar only to have their mechanisms back drive and lower them down didn't get counted. The opposite holds true here, if you start upwards and when you stop moving have lifted a team into bonus territory, then they count.
Wetzel
Viva Olancho!
Unread 12-01-2007, 11:40
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Obviously safety must be considered; you don't want people entering the field believing that your machine has come to a resting position when it is about to lift or actuate any mechanism.
That being said, we have discussed options of using pneumatic valves that will switch when powered off to trigger any number of mechanical operations. Given that everything else should come to a static position with a second or two it is probably best if any continuing activity would be obvious in this time frame and not have any considerable delays.
Unread 12-01-2007, 11:41
kawelch kawelch is offline
Formerly of 1653
FRC #1984
kawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to behold
OK... Let me see if I undersand. The game is not 2:15 but is infact 2:15 + "End of play". Like the last play of a football game, if you have hiked the ball before time expires you can continue until the play is over.
Unread 12-01-2007, 11:43
Wetzel's Avatar
DC Robotics
At 2:15 power to the robots is cut. If your robot is at full tilt and can coast, the match is not scored until it comes to a rest. The same goes for any ringers in the air.
Wetzel
Viva Olancho!
Unread 12-01-2007, 11:46
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
You just need a intricate Rube Goldberg machine on your robot that is set into motion as the power is cut that magically can score a couple ringers, lift a couple robots etc. No problem right?
Lifting robots rjbarra Technical Discussion 8 09-01-2007 01:23
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
Goal Lifting!?!?!?! kacz100 General Forum 13 21-02-2002 15:39
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
