Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 12-01-2007, 13:28
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
Re: Camera & Default Code
I will wait,
what zip file? the one for the camera?
and then what will i have to do to get working on the complete code (including camera and everything, the code that will be used in the competition)?
Thanks,
Carmel
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 12-01-2007, 14:07
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Lablabla View Post
I will wait,
Thanks,
Carmel
The software in the frc_camera_2.zip and frc_camera_s_2.zip files contains IFI's default code plus camera code that will find and track the green lights. In the next few days I'll update the code to also include a new PWM driver that will give you more control over your servos and cure PWMs 13-16 of their jitter.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2007, 14:18
AKA: Carmel Barak
Thanks, that's what i was looking for
Where can i find out when you've updated the file?
Thanks,
Carmel
LighTeam #1957
Unread 13-01-2007, 13:20
aviv aviv is offline
FRC #1657
aviv will become famous soon enough
You can find it on Kevin's website.
http://kevin.org/frc/
Winner of 2006 GM/Technion Israel Regional
Chairman's Award 2006 GM/Technion Israel Regional
Best Website 2006 GM/Technion Israel Regional
HaMosad Robotics #1657
Unread 16-01-2007, 16:04
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
We have managed to get the camera tracking beautifully. Thanks so much Kevin. I have a question though.
We were able to change the PWM's that the servo's use (PWM01/PWM02) to PWM07 and PWM08. Everything still works fine i.e. camera tracks. Our question is, where do we set PWM01/PWM02 so that they are now free for us to use with a joystick (y-axis) vis-a-vis the default non-camera code. Thanks for your help.
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
Unread 16-01-2007, 17:16
AKA: Carmel Barak
If I understood your question:
in the project downloaded from kevin's site
the Default_Routines() function in the user_routines.c is commented
uncomment it (where it's being called) and edit it at the bottom of user_routines.c
you decide what pwm is for what joystick axis at that file too.
If I didn't get your question right, forgive me and ignore the answer
Carmel
LighTeam #1957
Unread 16-01-2007, 18:33
FRC #2429
Originally Posted by dmellich View Post
...Our question is, where do we set PWM01/PWM02 so that they are now free for us to use with a joystick (y-axis) vis-a-vis the default non-camera code. Thanks for your help.
I think Q22 in the CMUCam2 FAQ answers your question. If not, please let me know.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2007, 19:15
AKA: Mr. E
Kevin, I remember reading through your Q&A and seeing that. My apologies for not paying better attention. Thanks again for your help.
David M. Ellich
Unread 28-01-2007, 18:10
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
Dear Kevin,
We are using your edu_camera.zip code with our EDU and it's working perfectly. You are awesome! Thanks.
Of course, the question comes to my mind, are we missing anything by not using the frc_camera21.zip code? The newest date on the files in the edu zip is 1/22/06 and it looks like you've updated several files since then in the 21 zip.
Is the only difference between the camera21 and the edu code just the linker and lib files because of the different PIC?
Your time and efforts are greatly appreciated.
Unread 28-01-2007, 18:25
FRC #2429
Originally Posted by michael714 View Post
Dear Kevin,
Looks like a few people want to use the EDU-RC with the camera, so I'll look into updating the EDU build with newer camera code. My kids are trying to drag me off to the "Epic Movie", so it'll be tonight or tomorrow before anything is up.
-Kevin
Kevin Watson
http://kevin.org
Possible danger using default camera code Mike Programming 3 07-02-2006 23:28
default camera code edit Windward Programming 8 25-01-2006 18:33
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Default Camera Code Flowchart cprogrammer Programming 1 27-02-2005 11:04
