Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 12-01-2007, 12:54
free_rider_151 free_rider_151 is offline
FRC #2039
free_rider_151 is an unknown quantity at this point
Can you mount the tires directly on the gear box?
I'm from a rookie team so I haven't done this stuff before. I was wondering if you can mount the wheels directly to the gear box. I wasn't sure if it'll burn out the motor or ruin the gears and bearings in the gear box. Does anybody know?
~Olav Oksnevad
team 2039
Unread 12-01-2007, 12:57
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Can you mount the tires directly on the gear box?
The gear boxes are not designed to carry that much load, so it would not be a good idea.
Unread 12-01-2007, 13:01
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
Personally i think that the gearboxes will be able to handle such loads if you support the other end of the shaft. My team is mounting 6" colsons onto the gearbox, cutting the shaft a little bit shorter, and then using bushings to support the other end. These gearboxes were originally designed by team whyachi for combat robotics, they are pretty robust.
--Dan
Unread 12-01-2007, 14:01
dtengineering's Avatar
AKA: Jason Brett
The 12:1 banebots gearbox is quite capable of supporting a wheel, although it would be an extremely good idea to make (or buy... banebots has one for sale) a bearing block to support the outboard end of the gearbox shaft.
Supporting the wheel with bearings on both sides prevents you having a cantilevered load on the gearbox which can put a lot of torque (twisting force) on the bearings in the gearbox.
Something important to consider when looking at a direct mount of the wheel to the gearbox is whether it gives you a combination of speed and pushing power that matches your game strategy. With direct drive the larger the diameter of your wheel, the faster you will move (to a point), and the smaller the diameter of the wheel the more pushing force you will have (again, to a point). Most of the common FIRST wheels are in the 4" to 8" diameter range and should work reasonably well, although if you have the larger wheels you may wish to consider purchasing the conversion kit to take your gearbox to 16:1, giving you more torque (pushing) but at less speed.
Keep in mind when building and testing your robot that the playing surface is going to be carpet. This does not matter so much when it comes to going forwards and backwards, but when you are turning your wheels may need to skid to the side... there are several options discussed on several other threads that you may want to search for surrounding this topic.
Jason
Unread 12-01-2007, 14:07
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Chances are it will but you really wouldnt want to do that, the speed would be too fast with no step down. The torque curve wouldnt match up to the speed and load.
Hows my searching? Call 1-800-Green-Dots
Unread 12-01-2007, 14:33
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
No problem with speed if you use smaller wheels. With a CIM and that 12:1 transmission and five inch wheels, you'd go about 8fps.
Unread 12-01-2007, 14:57
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Really? I think with a careful driving strategy and the right type of wheels, speeds like that can have quite an advantage.
Unread 12-01-2007, 23:32
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
We calculated that we would go just under 9fps if we ran the kitbot wheels (6") on the 16:1 transmission with a CIM. We used the max RPM of 5342, which we got off the FIRST Wiki. Just another alternative
Unread 13-01-2007, 01:47
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Remember that the 5342 RPM number is the approximate free speed of the CIM motor. When placed under load, the motors will run quite a bit slower than their free speed.
--Madison--
...down at the Ozdust!
Unread 13-01-2007, 09:04
Interesting; I was under that suspicion but I assumed that the drop in RPM would be fairly small. In that case, my question becomes: How can you accurately calculate the FPS of the robot based on the loaded speed of the motor?
How do you mount the encoders to the Gear boxes? waialua359 Technical Discussion 5 01-02-2006 21:07
Information on gears inside the FP Gear Box? David Guzman Technical Discussion 2 19-05-2005 23:09
mounting of the small gear directly to the shaft of the drill Andrew Dahl Motors 0 19-01-2004 12:18
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
the motor mount with gear switch newatthis General Forum 4 15-01-2002 22:07
