Re: 2007 Motor Specs
Does anyone happen to know specs on the pinion gear attached to the Keyang motor? Based on the outside diameter, I was able to figure out that it appears to be a 12 DP gear. If someone could verify this for me that would be great. But now that leaves the question of what pressure angle the gear is... does anyone know?
Also, as far as I can tell, this is very similar, if not equal to the Keyang model PWM-60B. http://www.keyang.co.kr/english/prod..._code=E0201004 The torque curve data also matches up with what FIRST has published. So pretty much, does anyone know the pressure angle of this pinion gear? If we knew then everyone could use it without the included plastic coupler and without making a custom coupler. Thanks. |
does anyone know where where I can get drawings/CAD/specs of the planetary gearboxes of the RS-540 motor? bane doesnt have it, neither does firstcadlibrary...it doesnt matter what ratio
More Specifically, we need the dimensions of the placement of the #10-32 holes on the face of the planetaries. We have measured with calipers, but our values are kind of fuzzy and don't make sense to me. I'd like an official drawing or cad if there is one. I'll email baneots tonight I guess.
| Motor Specs??? | tenfour | General Forum | 1 | 10-01-2003 17:56 |
| motor specs? | Gary Dillard | Motors | 0 | 04-01-2003 17:54 |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 23-01-2002 08:58 |
| Chiapua motor specs? | Nick Boyajian | Motors | 2 | 09-01-2002 06:14 |
| Motor specs | kmcclary | Off-Season Events | 4 | 26-10-2001 22:41 |
