Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 12-01-2007, 16:16
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
can bots with omni wheels capable of going up robots?
Are robots with omni wheels capable of going up robots with ramps? i mean is there enough traction?
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Unread 12-01-2007, 16:18
in between teams
AKA: Luke Van Oort
Re: can bots with omni wheels capable of going up robots?
I'm pretty sure this is an impossible question to answer considering the different applications of omnis (tank steered and holonomic) as well as the different materials/angles teams might design their ramps with.
Team 1219: 2009 - Mentor
Unread 12-01-2007, 16:20
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We did last year! It was pretty easy! As long as the traction wheels go up last
Faridodin "Fredi" Lajvardi KD7WKD
Unread 12-01-2007, 16:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Do you mean using omni-wheels in a traditional scrub (tank) steering drive, or a full fledged omni-directional drive-train (holonomic, mecanum, etc.)?
Unread 12-01-2007, 20:43
Niffer's Avatar
Niffer Niffer is offline
AKA: Jennifer
FRC #1189 (The Gear Heads)
Niffer is an unknown quantity at this point
Send a message via AIM to Niffer
Its also hard to tell becuase from what our team has calculated the ramps are gonna be pretty steep this year
Johnny was a chemist son
but Johnny is no more
What Johnny thought was H2o
was H2SO4
Check out our team 1189 http://www.gpgearheads.org
Unread 12-01-2007, 21:45
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
last year I saw some teams with holos climbing up on ramps . . they got a good running start but they did it.
also I think the ramps this year are going to be easier than last . . least all the ramps Ive seen are
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 12-01-2007, 22:01
cgdtgurl07 cgdtgurl07 is offline
drive train/ mechanic
AKA: Autumn
FRC #1741 (Red Alert)
cgdtgurl07 is an unknown quantity at this point
Send a message via AIM to cgdtgurl07
People saw how hard it was for some people to get up the 30 degree ramp last year so i'd venture to say the ramps won't be that steep. we had omni wheels in the front last year and we got up the ramp pretty well. like said before...as long as you have the traction in the back, you'll make it if you have enough power with it.
Unread 12-01-2007, 22:49
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
I think tank style might be able to go up a 20 or 25 degree ramp, but any other steering style won't go up a ramp.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 12-01-2007, 22:50
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
With enough traction and how small these ramps will be, it shouldn't be a problem. Plus, if you code a gyro to make you drive straight, you don't have to worry about swerving to the side.
Unread 13-01-2007, 01:05
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
I doubt a omni-wheel holonomic can, but I think both a omniwheel+treaded wheel and a mecanum wheel robot can go up a graudal ramp.
Unread 13-01-2007, 01:19
Our off-season practice mecanum drive base drove up last year's ramp without difficulty -- if it was perfectly lined up. Any significant error in approach angle made it lose traction on one corner or another, making it spin or slide unexpectedly away.
Unread 13-01-2007, 15:49
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
The main difference between last year's 30 degree ramp and a 30 degree ramp (or steeper) this year will be the material the team chooses to make the ramp out of. A team could add grooves and use a material that provides more traction than diamond plate... I don't expect ramps to be much of a problem for many drive systems this year... as long as the ramp isn't made out of something like teflon.
Unread 13-01-2007, 16:15
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Last year we used two pnuematic wheels and two undriven omni wheels. We made it up the ramp with a running start and the omni wheels in the back. If we tried putting the omni's in front, they usually slid sideways.
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Motors with Omni-Wheels jlewellen Motors 5 11-01-2006 23:24
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
Omni Edu Bots... CHS_Tommy Robotics Education and Curriculum 18 19-03-2004 22:42
