Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 12-01-2007, 22:33
King Duke's Avatar
King Duke King Duke is offline
FRC #0991 (Dukes)
King Duke is a jewel in the roughKing Duke is a jewel in the roughKing Duke is a jewel in the rough
Send a message via AIM to King Duke
Re: pic: Team 437 OffSeason
Originally Posted by NextPerception View Post
we are using 6 kit of parts tanks and one large tank near the front of the robot for our pneumatics. also a 20lb tank of Co2 for firing the thing. we compress the pneumatics tanks with TWO kop compressors.
for your second question. originally we where using two sprinkler valves. one for filling the firing tank and the other to use as a pilot for The SGTC Supah-Valve. we eliminated the sprinkler valve to fill the firing tank however just because it was redundant and because it was run off a normally closed solenoid, the solenoid was open most of the time, and we where running the ac solenoid of 24volts dc. as a result, it was getting quite toasty and we didn't wanna risk a failure. plus. the fewer parts there are, the fewer that can fail.
also, if anyone wants a larger shot of the robot, try here and here
if you want more detailed shots or better quality video, feel free to send me a HD camcorder or 11megapixel camera
yes btw, for those with keen eyes, that is the year 2000 First Controller. Team 437 really broke out the bleeding edge technology on this bad boy.
how did you guys get such a good seal on the breech?
Unread 14-01-2007, 12:50
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
well our breach is constructed from 4 3" pipe couplers with the ridge taken out of them on a lathe and then those all had there outside dimension taken down a little on the lathe as well so that they would slide into a 4" pipe. we then pvc cemented the whole thing together and then just let it dry. it seals perfectly.
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
pic: 437 a week ago NextPerception Robot Showcase 1 22-02-2006 23:04
pic: Best Offseason Fundraiser Part 2 - 175 is at it again!?!?! CD47-Bot Extra Discussion 18 16-08-2004 08:43
pic: Best Offseason Fundraiser CD47-Bot Extra Discussion 14 13-08-2004 00:00
Seeking other NORTEL NETWORKS Teams - #'s 296, 408 & 437 archiver 2000 3 23-06-2002 22:41
Thank you teams 364 & 437 archiver 2000 0 23-06-2002 22:33
