Go to Post I thought of this at least a couple of years ago, but I didn't post because I didn't want to give Dave any fiendish ideas. He has enough without our help. - ChrisH [more]
Unread 12-01-2007, 22:42
Alex G Alex G is offline
FRC #0201 (FEDS)
Alex G is an unknown quantity at this point
Re: 2 Cmucams?
Technically, he is right. in an UART, each byte is 10 bits (1 start, 8 data, 1 stop). running at 115200 continuously gives 115200/ 10 * 2 interrupts / second for the recievers alone.
Of course, the PIC can handle that, considering that the cameras will not continuously send data, however, a few thousand interrupts per second will be generated.
Unread 12-01-2007, 22:49
Re: 2 Cmucams?
The UART only triggers interrupts when it a packet hits on the Rx side. The CMU cam only puts out a few hundred interrupts per second.
Unread 12-01-2007, 23:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: 2 Cmucams?
Okay, whatever
-Kevin
Kevin Watson
http://kevin.org
Unread 13-01-2007, 01:05
Electrical Engineer
Rookie Year: 1995
Re: 2 Cmucams?
All,
While we did not run 2 cameras, in 2005 we moved the camera to port 1 (programming port) and installed a SMiRF on port 2 to enhance code development.
We had no problems with interrupt overhead.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 14-01-2007, 14:52
FRC #0201 (FEDS)
Re: 2 Cmucams?
Originally Posted by Kevin Watson View Post
Okay, whatever
-Kevin
We can choose to argue about the details, but the point that we agree on is that the Robot Controller can easily handle 2 CMU Cam's with your code.
Unread 14-01-2007, 15:23
FRC #2429
Re: 2 Cmucams?
We can choose to argue about the details...
I don't choose to argue about anything. I'm right and you're wrong. The serial data from the camera generates just over one hundred interrupts per second, not "a few thousand" and certainly not "11520".
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2007, 16:03
FRC #0201 (FEDS)
Re: 2 Cmucams?
-Kevin
You're right. I believed that the data packets were larger, but after checking the code carefully I found that I was wrong. Sorry if I seemed too jumpy.
