Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 08-01-2007, 04:13
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
2 Cmucams?
I figured a bit of stereovision would be neat this year, and plan to use two CMUCams. My question is this - how would I hook them up? One would obviously be hooked up via the TTL-RS232 converter, and the other one? Into the programming port, possibly?
I looked at Kevin Watsons serial drivers, and this might be a possibility.
Anyone else have any ideas?
Unread 08-01-2007, 09:39
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: 2 Cmucams?
yeah you can hook up the second camera to the programming port. in kevin watsons code there is an option for enabling this serial port. It is used in the same exact way as the ttl port
Unread 08-01-2007, 15:21
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: 2 Cmucams?
You would actually have to duplicate Kevin's code, IIRC. Otherwise, I think the states will trample on each other.
Unread 08-01-2007, 15:27
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: 2 Cmucams?
I think that many interrupts per second would kill the controller anyways. 11520 interrupts a second x 2.
Unread 08-01-2007, 17:05
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: 2 Cmucams?
Again, you don't have a clue what you're talking about. Please stop spreading disinformation around the forums.
The camera only generates a few hundred interrupts per second, one per byte received. The serial driver is very efficient and can easilly handle this load.
Furthermore, there is no reason that you couldn't have two instances of the camera code running, you just need to make sure each instance isn't using the other's global variables.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2007, 22:42
Alex G Alex G is offline
FRC #0201 (FEDS)
Alex G is an unknown quantity at this point
Re: 2 Cmucams?
Technically, he is right. in an UART, each byte is 10 bits (1 start, 8 data, 1 stop). running at 115200 continuously gives 115200/ 10 * 2 interrupts / second for the recievers alone.
Of course, the PIC can handle that, considering that the cameras will not continuously send data, however, a few thousand interrupts per second will be generated.
Unread 12-01-2007, 22:49
Re: 2 Cmucams?
The UART only triggers interrupts when it a packet hits on the Rx side. The CMU cam only puts out a few hundred interrupts per second.
Unread 12-01-2007, 23:39
FRC #2429
Re: 2 Cmucams?
Okay, whatever
-Kevin
Kevin Watson
http://kevin.org
Unread 13-01-2007, 01:05
Electrical Engineer
Rookie Year: 1995
Re: 2 Cmucams?
All,
While we did not run 2 cameras, in 2005 we moved the camera to port 1 (programming port) and installed a SMiRF on port 2 to enhance code development.
We had no problems with interrupt overhead.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 14-01-2007, 14:52
FRC #0201 (FEDS)
Re: 2 Cmucams?
Originally Posted by Kevin Watson View Post
Okay, whatever
-Kevin
We can choose to argue about the details, but the point that we agree on is that the Robot Controller can easily handle 2 CMU Cam's with your code.
Unread 14-01-2007, 15:23
FRC #2429
Re: 2 Cmucams?
We can choose to argue about the details...
I don't choose to argue about anything. I'm right and you're wrong. The serial data from the camera generates just over one hundred interrupts per second, not "a few thousand" and certainly not "11520".
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2007, 16:03
FRC #0201 (FEDS)
Re: 2 Cmucams?
-Kevin
You're right. I believed that the data packets were larger, but after checking the code carefully I found that I was wrong. Sorry if I seemed too jumpy.
