Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 12-01-2007, 17:03
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
pic: Basic chassis done
Unread 12-01-2007, 17:04
AdamHeard's Avatar
Lead Mentor
Re: pic: Basic chassis done
I'm just curious as to why you are running dual wheels in the back.
There is no additional traction gained, the load is more spread out but a single wheel is plenty strong.
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I like the smooth look. What are you going to cover your wheels with?
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 12-01-2007, 17:07
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
It really looks nice as usual guys! It looks like it has a pretty low ground clearance. With all the talk of ramps on robots this year do you have a plan to clear any ramp peaks so that you don't "high center"?
Unread 12-01-2007, 17:44
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
i like that a lot. 4 back wheels is an interesting choice, but i'll defer to the designers on this one as to how useful they'll be.
Unread 12-01-2007, 18:32
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Actually you have less traction because there is less ground pressure.
Looks nice and clean
How much does it weigh..it looks heavy
MechWarriors 573
Unread 12-01-2007, 19:16
cinderblock cinderblock is offline
Team 8 2006 Captain
AKA: Cameron Tacklind
FRC #0008 (PALY Robotics)
cinderblock is an unknown quantity at this point
Send a message via AIM to cinderblock
Less pressure over a greater area. Friction force calculations go as the normal force times the coefficient of friction. Area is not used in the calculation of friction.
So why extra wide wheels in the back?
Unread 12-01-2007, 19:26
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by cinderblock View Post
...So why extra wide wheels in the back?
one upside of having a large surface area is that the traction material will wear more slowly than a narrower wheel; more surface area means the forces are more widely distributed.
Also, while friction is not dependant on surface area, traction can be, under the right circumstances. for example, back in 2002 when you where allowed to lift 180# goals, teams would often tear up carpet fibers; the teams with narrow, high traction tires more than those with larger surface areas. by increasing the contact area, you spread the force around, so an individual carpet fiber is less likely to fail. more surface area, more carpet fibers sharing a given load.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 12-01-2007, 22:59
AKA: Ledge
Right now it weighs 45lbs but have yet to "cheese" it
Faridodin "Fredi" Lajvardi KD7WKD
Unread 12-01-2007, 23:09
AKA: Ledge
You guessed it! It keeps us from having to repair the treads on the IFI wheels, we saw teams having to fix them frequently, last year we used this setup and never repaired one! Even though calculations show we loose some traction, we have not had a problem pushing everybody around. Plus it just plain looks cool!
Unread 12-01-2007, 23:10
AKA: Ledge
Pavan.
IFI roughtop tread
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: 1018 - Pic 4 - Welded Chassis Stu Bloom Robot Showcase 17 03-02-2006 21:36
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
basic chassis (the supplied one) diagrams and directions Andrew Dahl Technical Discussion 7 15-01-2004 19:59
