Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 12-01-2007, 18:06
Naveen Naveen is offline
FRC #1923
Naveen is an unknown quantity at this point
Green Camera Light Questions
How should we power the lights? Can we connect them directly to the 12 volt or do we have to go through some other circuitry or get a seperate batteries.
Unread 12-01-2007, 18:16
dtengineering's Avatar
AKA: Jason Brett
Re: Green Camera Light Questions
Any half-decent 12V source should do... and the main robot battery is definitely a decent 12V source. Any car battery should also do the trick.
Just remember that the camera is neither required nor the only means to find the rack.... although it is undoubtedly an exceptionally cool means of finding the rack.
Jason
Unread 12-01-2007, 18:18
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
You are going to want to put some sort of fuse or breaker in-between the battery and the light to prevent from shorting the battery directly (BAD). If you have any electrical parts lying around from previous years, just wire up a fuse block and connect the light to that.
Unread 12-01-2007, 23:42
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
I wired all the transformers to a small terminal block that we had laying around last year. I have a black and red wire stub that I hook to my "super 40 foot aligator clips of doom" Who says you can't run the robot and the light off the same battery?
The freshmen project for this saturday will be setting up the other two lights for us
Unread 13-01-2007, 00:20
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
I hooked up a pair of transformers (for the lights) to a 9v wall-wart from Radioshack, and I did the same for the other pair and the fan. It isn't pretty (I used about a foot and a half of electrical tape) but it works great!
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 13-01-2007, 00:32
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Yup... We wired all of ours up to a 12v wall wart we had laying around, and it works just fine, You'll want to watch leaving it plugged in though
Unread 13-01-2007, 00:46
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I recommend a sufficient AC powered transformer in place of robot batteries, as they get low the lights dim and your tracking/calibration gets really faulty, and its hard to tell from across the room. With a solid power supply you can be sure your problems will never stem from incorrect lighting.
Matt Krass
Unread 13-01-2007, 00:58
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
In the past we have used a power supply from a computer (one of the older ones with a push putton to turn it on.) It worked fine with no problems to speak of.
Unread 13-01-2007, 10:18
Netherlander Netherlander is offline
FRC #1006 (Fast Eddie Robotics)
Team Role: Electrical
Netherlander is an unknown quantity at this point
How does FIRST power the green lights on the field?
Unread 13-01-2007, 21:53
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I dunno, but it has to be a steady supply, and I'm sure they've got it more than covered.
Anyway, we jimmied a couple of last year's batteries and it works fine. Though looking at previous posts, it might be beneficial to try the wall-wart idea. We're having trouble as it is just calibrating the thing, low batteries shouldn't add to the fun.
Unread 13-01-2007, 22:08
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
i haven't done much this year, but from fun last year... callibrating in a dark area might be good. unless you think having the robot "look" at ceiling lights is benificial...
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Unread 21-01-2007, 19:45
Rabbit222's Avatar
Rabbit222 Rabbit222 is offline
reffed PARC for 3 yrs now
AKA: DA BUNNEY
FRC #0222 (Tigertrons)
Rabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really nice
Send a message via AIM to Rabbit222
Has anyone who used a 12V. AC adapter have any problems with the lights dimming out after about 4 minutes or so? My team has had this problem for the past two years now. We've checked our wire setup many times and we can't find anything that could be causing the problem. We are running through a large terminal block and that may be the cause of the problem, but we are not sure. We haven't gotten the chance to change it out yet. Also are there any teams who have florescent lights in their buildings? We have them and we cannot program very well because of the poor lighting. If you have this problem, how do/did you best get around it? We would really like to have a camera this year.
~Rabbit 222
PARC 12 CHAMPIONS 222, 2753, 1640
2009 Archimedes Champions with 2753 & 1218 Einstein Semifinalists
2009 Philadelphia GM Industrial Design Award
2009 Pittsburgh Champions with 1218 & 1743
2009 Pittsburgh Judges Award
2009 Pittsburgh Autodesk Visualization Award
2008 Pittsburgh Motorola Quality award
2007 Pittsburgh Finalists with 48 & 1038
PARC 9 CHAMPIONS 25,222,423
Unread 21-01-2007, 19:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
did you look at the current load of each pair of cold cathode lights, and the available power from the wall wart?
We estimated about 3 amps per light box, the old computer PS I gave the team is rated 5 amps on the +12v output
Most 12v wall warts are rated for one amp or less.
Unread 21-01-2007, 20:28
foote stepped in
AKA: E. Foote
FRC #0868
I remember last year we had our camera hooked up to just one battery. After about 2 weeks of working with it, all of a sudden the camera just wouldn't pick it up. After running some tests with it, we found that it was grossly out of focus. After much blaming of freshmen, we tried it out again. Still it wouldn't pick up the light. After running more tests, we found that the battery was low, and the light wasn't that perfect shade of green. whoops
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 21-01-2007, 20:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
~Rabbit 222
I think your problem with your light dimming after a few minutes is that you don't have a sufficient supply of power. I would recommend at least a 1500mA power supply. Also, we have florescent lighting in our building, as I would suspect most teams have and we don't have any problems. I'm thinking that your lights start off dim and just get dimmer, causing your camera to not see the light very well. We use one of our old ILLEGAL batteries and it works fine for about 4 hours without dimming, and then it takes about 2 hours to charge back up. You can purchase a 12V power regulator and put 2 batteries in series and it will give you a steady level of light, just make sure your voltage regulator can handle 30 volts. I say 30 volts because when you charge a battery, the voltage is above 12 volts, and 15 volts should be the maximum voltage your battery should ever get. Hopefully this helps...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
KOP green light 987HighRoller Kit & Additional Hardware 1 13-07-2006 23:18
Green Light Power Source BobC Kit & Additional Hardware 19 20-01-2006 14:44
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
Green Light Rachika Garcia Kit & Additional Hardware 1 10-01-2006 08:46
