Go to Post Upon entering FIRST you immediately apply Murphy's Laws. - A_Reed [more]
Unread 12-01-2007, 22:57
Generator of Entropy
FRC #2973 (The Mad Rockers)
Exceeding 72 x 72 - Penalty?
If you exceed the 72 x 72 envelope outside your home zone, what is the penalty? DQ? I don't see it anywhere. Suppose you are deployed > 72 x 72 in your home zone and you get pushed out by the other alliance, same penalty? If it's DQ, sounds like a possible strategy.
I'm submitting this to Q&A, just thought I'd get CD reaction.
Unread 13-01-2007, 01:25
dtengineering's Avatar
AKA: Jason Brett
Re: Exceeding 72 x 72 - Penalty?
I suspect it is the sort of thing that would be checked out during tech inspection just as all other sizes and weights are. It would be extremely difficult to take a measurement of maximum extension during a match.
Or perhaps it will be a situation where you will only be checked in detail if it appears to the refs that you might be close to exceeding the expanded size limits... in which case, I suspect, you would not be allowed to compete until you had modified the robot in such a way that it could no longer exceed the 72" limit.
But that is probably a good question for the GDC on the FIRST Forums.
Jason
Unread 13-01-2007, 01:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Jason
The problem with this is that there are some cases (specifically, when you are in the home zone) where you can exceed 72x72. Just because you exceed those dimensions during inspection doesn't mean that you will do so when it's illegal. That's what makes this rule somewhat harder to enforce than, say, the ball speed limit from last year.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-01-2007, 08:27
That was the point of the question - you can legally exceed 72 x 72 this year, but only in the home zone. But if you deploy before you get there, or you leave the home zone, or you get pushed out of the home zone, what is the penalty? It doesn't say. If it's a DQ, that's pretty major.
Unread 13-01-2007, 08:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think this rule can only be enforced if it is a gross and obvious violation of the rule. And in that scenario, if intentional (probably not being pushed out of zone, etc), you would probably be forced to modify your robot before being allowed to compete again. Similar to the the ball speed limit last year.
Unread 13-01-2007, 17:38
That makes sense, but what about this scenario: You design your robot so that you can push your ramp under your alliance partners if they are stuck. If you cross out of the home zone while doing that, is that gross and obvious? If you do it once? If you do it 3-4 times? With the ball speed, you were never allowed to exceed the speed limit; in this game it's not that fact that you exceed the envelope, it's the fact that you left the home zone.
My guess is that crossing the home zone really does not violate the intent of the rule, which is to limit robot size as you're driving around the field.
Unread 13-01-2007, 21:50
foote stepped in
AKA: E. Foote
FRC #0868
if the opposing team pushes you out, the referees will definitely not call a DQ on you. Kind of like if a team intentionally drives up onto your ramp, and tips themselves over. If your team didn't move, then there would be no way that you could be DQed for being a ramp.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 13-01-2007, 21:55
Says who? Common sense says yes, refs may say no (on the last part--teams driving up ramps to tip over). It's happened before.
Unread 15-01-2007, 14:52
rwwman50's Avatar
rwwman50 rwwman50 is offline
FRC #2016
rwwman50 is on a distinguished road
Send a message via AIM to rwwman50
Probably depends on timing if you do it within the End Game on the way home they probably won't penalize you at all but if you unfold at the start and go the whole game then they decide to checkit might be a DQ and possibly force you to modify the robot
Victory at all costs,
Victory despite all the terror,
Victory however long and hard the rode may be
-Winston Churchhill
So this is how liberty dies,
to showers of thunderous applause
-Star Wars Episode III
WAR is PEACE
FREEDOM is SLAVERY
IGNORANCE is STREGNTH
-Orwell 1984
Unread 16-01-2007, 00:19
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
I didn't see the following question posed in the FIRST Q&A:
What is the penalty for unintentionally exceeding the 72"x72" limitation?
(i.e. early deployment of ramps outside of the home zone - either via interaction with other robots or operator error)
If the result is a DQ, then "wide body" robots might want to stay in the home zone for the entire match!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 16-01-2007, 12:28
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Is this posted there or not? I couldn't find it... and it's a question that needs to be asked...
At the same time, a clearer definition of "PLAYING CONFIGURATION" needs to be requested as well. Is it a different playing configuration at every point in the movement of an arm that might exceed the 72" square?
If you're using a narrow arm that's centered on your robot and gets penalized, could you argue that by rotating the square 45º, your robot fits within THAT square?
Unread 16-01-2007, 16:59
I asked the question in Q&A; the response has not been posted yet.
The question about fitting diagonally into the 72 x 72 envelope has already been asked and answered in Q&A. Orientation does not matter, so yes a narrow arm plus your robot length can exceed 72 inches. (and I'm using every inch of that diagonal - another benefit of the octagonal frame which allows you to sit farther back in the diagonal).
Unread 17-01-2007, 13:38
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
This is mere speculation, but common sense would dictate that an opposing team trying to drive up your ramp while in your home zone would likely be interpreted as a violation of <G35>:
A ROBOT may not attach to and/or climb onto a ROBOT on an opposing ALLIANCE (doing so will be interpreted as an attempt to damage an opposing robot, and may be penalized as such).
If an opponent deliberately tried to climb you while stationary, I would expect you not to be penalized, and that the opponent might even receive a penalty or DQ. (Eric, I know that this unfortunately was not always the case, particularly for your team in 2005.)
_
Unread 17-01-2007, 13:50
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If any part of your robot crosses the home zone line, then you are out of the home zone and must stay within the 72" X 72" restrictions. If you are pushed by an opposing robot, home zone violations are not counted as long as you make a visible attempt to either enter your own home zone or leave the opponent's home zone.
Hi!
Unread 18-01-2007, 09:34
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
There are several "What If" scenarios where the robots will pass inspection but may violate one of the size or wedge rules. The inspectors will only look at the starting configuration to verify the dimensions and the robot meets the wedge rules. But when it comes to arms, ramps etc…, the inspectors cannot know when they will be used during the match. If there is a potential for a rules violation, the inspector may notify the teams but the robots will pass inspection.
There is no obvious answer to the original question. I would keep an eye on the Q&A board for updates.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
About being overweight and exceeding your size requirements – the need for reinspecti Godzilla! General Forum 48 28-03-2006 11:11
Off Side Penalty? Athenian Roboti Rules/Strategy 43 25-02-2006 16:35
Forced offside penalty? firstborn Rules/Strategy 9 11-01-2006 20:56
30 Second Penalty kjohnson Rules/Strategy 5 16-01-2004 23:14
scoring penalty unfair archiver 2000 4 23-06-2002 23:55
