Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 13-01-2007, 14:01
Grovestand Grovestand is offline
FRC #1599
Grovestand has a little shameless behaviour in the past
Ramp dimensions
Hey, ive scanned the manual for any information on this but i would like to clarify.
Are there any dimension limits for ramp angles?
If so, where are they stated in the rulebook?
Unread 13-01-2007, 14:07
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
Re: Ramp dimensions
i dont see any rules on the dimensions of a ramp on your robot, as long as it doesnt exceed the basic maximum weight/hight/length limits of your overall robot
Unread 13-01-2007, 14:13
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Re: Ramp dimensions
At the beginning of the match, the robot may not extend beyond 28'' wide by 38'' long. But,
<R12> Once the match has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R07>. While outside of its HOME ZONE, a ROBOT may expand up to a maximum width of 72 inches and depth of 72 inches. While entirely inside of its own HOME ZONE, there is no limit to the maximum width or depth of the ROBOT, as long as it remains entirely within the HOME ZONE. There are no height
limits for a ROBOT in its PLAYING CONFIGURATION at any time after the start of the match (other than those naturally created by the ceiling height of the competition venue).
Based off of this rule, I would say that you can have a ramp of any angle as long as it can either: 1) Stay entirely within your home zone, or 2) Not extend the robots dimensions beyond 72'' by 72''.
The HOME ZONE is the 8 foot by 26 foot 8
inch area bordered by the diamond plate wall of the Alliance Station, the polycarbonate walls of the playing field, and a colored line on the playing field.
So you could, in principal, make your robot 72 inches wide and long and 1 foot high. If you are against the home zone wall, your ramp could extend the remaining 2 feet to the edge of the home zone. On a perfect robot in this position, the ramp could be 26.8 inches long, or 2 feet 2 and 4/5 inches. The ramp angle would be 26.6 degrees. This would give you the ability to hold both of your alliance partners, as long as they're small enough, and have the lowest possible angle.
But if you don't extend beyond the starting dimensions, your robot could line the long end (depth) against the alliance station wall and extend your ramp from the side. This would give you 5 feet 4 inches to have a ramp extend. In this configuration, your ramp could be 5 feet 9 inches long, and would have an angle of 10 degrees. You'd only be able to hold one of your partners at most, but that is a very low angle that almost any robot could ascend.
2006 Boilermaker Regional
2006 Buckeye Regional - Third place overall
2006 Atlanta Finals
2006 IRI
2007 Boilermaker Regional
2007 St. Louis Regional
2007 Finals (hopefully )
2007 IRI
Why, yes. I do know what I'm doing!
Unread 13-01-2007, 14:17
FRC #1599
Re: Ramp dimensions
yeah, thanks =D we were just making sure there werent any strict angle limits, for some reason we were led to believe that the ramp had to be 20 degrees. bad rumors =P
Unread 13-01-2007, 14:23
Dancing_Chuck's Avatar
Dancing_Chuck Dancing_Chuck is offline
AKA: Chuckles
FRC #1111 (Powerhawks)
Team Role: Electrical
Dancing_Chuck will become famous soon enough
Send a message via AIM to Dancing_Chuck
Re: Ramp dimensions
Yeah, I think that Jones answered that really well. Thanks, I had the same question.
You can dance if you want to, you can leave your friends behind
'Cuz if they don't dance when you want to dance, then they're no friends of mine!
http://video.google.com/videoplay?do...60835799858748
Unread 13-01-2007, 14:55
Spark Hawk's Avatar
Spark Hawk Spark Hawk is offline
Alumnus
AKA: Patrick
Spark Hawk is an unknown quantity at this point
Re: Ramp dimensions
I know... I absolutely love the fact that the home zone is restriction free.
Unread 13-01-2007, 14:56
Rack & Roll, baby!
Re: Ramp dimensions
I love math...
2006 Atlanta Finals
2006 IRI
2007 IRI
Unread 13-01-2007, 15:01
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
Re: Ramp dimensions
if you are thinking about making a rampbot, make sure that your angle is not too extreme and that basically any robot would be able to get up onto it. Remember last years ramp and how steep/short it was, and that atleast 30-40% of the robots were not able to consistently get up on it. Also remember this is going to be a last minute dash for the most part and robots will only have maybe one shot to get up onto the ramp, so it should be fairly easy for them to get up.
Good luck!
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Dimensions Andrewpbhs Technical Discussion 3 04-12-2006 18:48
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
scoring ramp dimensions archiver 2000 3 24-06-2002 00:13
Ramp Dimensions archiver 2000 5 23-06-2002 22:37
