Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 13-01-2007, 14:48
kasemodz kasemodz is offline
None #0540
kasemodz is an unknown quantity at this point
program camera
I used the kevin.com site to download the frc camera stuff. I used the workbook provided and I'm trying to program the camera. Right now I have power connected from analog output from the controller. I tried using a pwm but it never receives a problem. I tried using a multimeter to measure the voltage on the pwms but I don't receive any kind of power. So I used the 5v that should work. Also I have the serial port connected to the computer. I switch it on, everything is good, there is a red and green light on. I press the program button but it never changes to orange. Plz help quick. thanks.
Unread 13-01-2007, 15:18
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Re: program camera
First of all, you need to have a pwm cable connected to both servos on the camera, and you need a ttl port to power the camera. When you try to download code to the robot, is the robot tethered to the controller? Also, you need to have a backup battery connected in order to power the camera.
:Edit:
Just do what he says.
V
2006 Boilermaker Regional
2006 Buckeye Regional - Third place overall
2006 Atlanta Finals
2006 IRI
2007 Boilermaker Regional
2007 St. Louis Regional
2007 Finals (hopefully )
2007 IRI
Why, yes. I do know what I'm doing!
Unread 13-01-2007, 15:59
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: program camera
Make sure you've done everything mentioned in #1 of the FAQ: http://kevin.org/frc/camera/
-Kevin
Kevin Watson
http://kevin.org
EasyC Program For Camera? G1279 Programming 1 08-01-2007 19:00
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Using Easy C to program the camera. Tazlikesrobots Programming 5 19-02-2006 21:33
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
