Go to Post The 4-wheel drive systems bounce around like Mexican jumping beans. It is quite fun to watch. - Warren Boudreau [more]
Unread 13-01-2007, 15:11
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
Mounting gears
How do you do it what do you need to do. It doesn't tell you how to get the gear to stay on?
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
Unread 13-01-2007, 15:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Mounting gears
We need some more information regarding what specifically you are trying to do to give you detailed help.
There are a variety of ways where you can have a gear stay in position on an axle. Set screws, clip rings, shaft collars, etc.
Unread 13-01-2007, 15:30
Loki1989's Avatar
AKA: Mike Parker
Re: Mounting gears
I have looked at it again and the axel has a notch for a along it. the gear has a like notch the same size and I cannot figure out what came to make it lock. because so far I think I need a pin that locks the axel and gear so they spin at the same time.
Edit: I have recently thet what I am looking for is a key and that it isn't in the kit... we have sent out a pair to get one hopefully for us.
Unread 13-01-2007, 16:10
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Mounting gears
When you're dealing with gears, sprockets, etc. in high torque applications you need to secure the gear from slipping on the shaft with a key. If you are talking about the BaneBots CIM gearboxes, the output shaft has a 1/8" key, so you will need a gear with a 1/8" keyway. If you can't find one, you will have to get one without a keyway and cut one yourself.
Key can be found at McMaster, just search for 1/8" key stock.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Battery Mounting Eria4044 Electrical 12 28-01-2005 07:40
Mounting Joysticks? LBK Rules Control System 12 19-01-2004 11:02
Drill Mounting archiver 2001 2 24-06-2002 00:39
mounting electronics nwagers Electrical 10 15-02-2002 13:09
