Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 13-01-2007, 15:51
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
Re: Help with the Kit Gear Tooth sensors
make sure it hasn't been damaged. last year we had a problem where our sensor worked, but had trouble with it's count. after noticing this problem, we found it had been damaged.
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Help with Gear Tooth Sensor RedOctober Electrical 3 27-01-2006 18:38
Source for Additional Gear Tooth Sensors Madison Kit & Additional Hardware 3 18-01-2006 16:57
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
