Go to Post FIRST is difficult and it is challenging, but you aren’t necessarily required to go off and build an 8 motor drivetrain and 4 motor / 8 pneumatic piston arm mechanism for the heck of it when a 2 motor non-shifting drivetrain and 2 motor arm does just as good a job. - Bill Gold [more]
Unread 13-01-2007, 17:31
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
Re: gear question
the exact meshing distance between two spur gears is determined by adding their pitch diameters, then dividing by two. (basically, you are adding the pitch radii)
Make sure to add about 3/1000s of an inch between your centers as your gears may grind if the meshing is too exact.
In this picture, pitch diameter is referred to as pitch circle:
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 13-01-2007, 19:40
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: gear question
Thanks I wasn't sure if it was that simple. I thought it was more complicated than that... oh well.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Question About Gear Boxes CE Mexican Motors 5 19-12-2006 15:14
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear reduction question dmellich Motors 6 25-01-2003 08:54
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
