Go to Post "We put the eek in Geek" - Wayne Doenges [more]
Unread 10-01-2007, 22:45
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Re: Main Power Terminal Blocks?
Ah yes, thank you.
And that's what I thought. Poo, now I get to redesign the electronics box.
void function(void)
  function();
Unread 11-01-2007, 08:27
The newly revised Tips and Guidelines is now available on the First website. As I was reviewing it, I found that the Guide shows what my belief for correct wiring of the negative lead blocks and 40 amp returns should be. Please review for your own electrical system design.
Unread 11-01-2007, 23:54
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Looking for some wiring advice
I am wiring up our power panel with the RC controller, spikes, and victors and have a few questions:
1. What guage wire is recommended to tie the heavy duty fuse block to the victors? These have 40 A fuses so I am guessing (10 or 12 awg?)
2. What about the fan motors on the victors? I am assuming these are12v- where do most people connect the fans to for power, (fuse panel for always on or something else)?
3. I am using 14 AWG between the fuse block and the spikes, is this the correct guage to use for this?
4. I got one small bag of quick connect push on terminal with our kit but these don't seem to be enough. Is ther ea problem with using any push on lug or do they have to be from the same mfg. that provided the ones in the kit?
5. Does anyone have a recommendation of which RC module output should control which spike or victor based upn the default code?
Thanks in advance.
Unread 12-01-2007, 00:26
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by sanddrag View Post
I don't mean to be un-gracious, but what is the point for this new power distribution block?
I looked briefly at the blocks, and the center jumpers. I noticed that the center jumpers look a little bit like a fuse...although I found no mention in the AB documentation of current limits of the jumpers in my brief reading.
But I do like the power blocks, they make me feel better about offering some protection in case the small wires from the 120 amp breaker to the individual fuse panels accidently shorted. I noticed that the wiring on last years robot offered no protection for certain types of wiring problems, and I think the new distribution block could make it safer.
(I'm an ME, not an EE, so maybe someone could tell me if I'm on the right track?)
Unread 12-01-2007, 01:14
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Looking for some wiring advice
Thanks in advance.
In the manual, Section 8 the Robot, Rules 87-98 will give you all the electrial specifics you are seeking.
In the default code from IFI, PWM01 is mapped to Joystick Port 1 X axis and PWM02 is mapped to Joystick Port 2 X axis. Typically they connect to the drive motor victors, but it's completely up tp you as to how you'ed like it to work
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 12-01-2007, 10:09
Thanks in advance.
Here are my recommendations...
#10 for all motor wiring other than perhaps the Globe.
Attach the fan wires to the power input to the Victor. This way you will know if the Victor is receiving power.
Follow the wiring restrictions for wiring the Spike by what size breaker you are using.
Purchase additional push on connectors from Digikey. We use the non-insulated type since we solder all connections following crimping and then cover with heatshrink tubing.
If you take a close look at the default code, you will see that the Victor PWM outputs are mapped to certain joystick input, use the ones that are for the joystick port(s) you will use in your design, either single or dual joystick. The spike outputs are your choice except if you use the compressor which again you will have to investigate the default docs for info.
Unread 12-01-2007, 10:12
MrForbes's Avatar
AKA: Jim
Al--Do you have a recommendation for where to connect the return (black) wire from each of any additional high power Victors (driving CIMs)? The power distribution diagram does not seem to suggest where they would go.
Unread 12-01-2007, 11:06
Japper's Avatar
Thank you Al- that is great advice!
Unread 12-01-2007, 11:15
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
Guys,
As much as these rail mounted blocks add weight and space, they are standard equipment in most modern electrical installations. Be sure to use the jumper accessory to connect all of the positive blocks together and all of the negative blocks together. These blocks will take #6 wire and I recommend using only #6 to feed the 40 amp Maxi block. It is best to strip back 1-1/2" of insulation and then fold over the strands, twice, so that they fill the entry hole in the Maxi block. This will give you a reliable connection that will not loosen over time.
Al-
We discovered that the blocks will take a #6 wire as well the other night. However if memory is correct a #6 wire will handle roughly 125amps. We did some research though and according to the Maxi block website the blocks are only rated for 85amps, meaning you should use only #8 wire. This is something that either a Q&A needs to be asked (Do we need to go through the Maxi block?) or teams will have to find out the hard way at their first regional (meaning the inspectors need to know).
-Mark
Unread 12-01-2007, 11:43
Jim,
See my post above, the Tips and Guidelines has been revised on the First website. Use the DIN blocks to return the 40 amp branches to the negative lead.
Unread 13-01-2007, 17:35
BradyP4 BradyP4 is offline
FRC #1517 (The Lumberjacks)
BradyP4 is an unknown quantity at this point
40 AMP returns revisited
I think the question WRT to the 40 AMP returns is that the diagram (in the power distribution diagram) shows only 3 40A returns. What if you are using 4 or more CIMs (4 2.5" and one 3")? Can the grounds be combined so that two motors share a ground terminal block or do we need to get more black blocks?
In the Guidelines 'corrected' diagram, they show only 2 40A returns, which makes it more confusing.
Deb
Unread 13-01-2007, 22:26
Phalanx's Avatar
My thinking is, I may be able to provide all service without the need for the ATC 12 or 6 breaker panels, so I need to ask, since I am uncertain.
Since we will need a 2nd Maxi-Block(total 2) because we need one more 40 AMP service(total 5) Can I use those 3 currently unused circuts on the 2nd MAXI-Block for lower amp services, for example the 20amp service for the RC, a 30amp service for a different motor on a victor, ect???
Would I also need more "Black" DIN blocks as well to now tie all those to ground?
Thanks!
Michael
Unread 13-01-2007, 22:45
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
The DIN rail when fully assembled makes the whole block negative and the other side positive. So in effect you may connect wires to both sides for positive and or negative (see attached picture). Hope that helps
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 14-01-2007, 10:01
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
So why is it in the rules that we must use these blocks?
if you look @ team 2200's wiring, i am now going to have to change it. Just so that i can run 2 power wires from the 120 amp breakers to the 2 Breaker Panels.
Do i have to use one for the negative side even tho i am just going from the battery to the one breaker panel?
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 14-01-2007, 11:00
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Does Anyone have the 1 – 199-DR1 din rail on hand so they could give me the slot dimensions? particularly how far apart they are
Terminal Blocks in Kit of Parts? Mark Pierce Electrical 13 24-01-2007 00:37
pic: Shaft Drive Bearing Blocks MAteo9944 Extra Discussion 25 01-01-2007 11:22
[OCCRA]: Pillow Blocks? Fizzix OCCRA Q&A 1 12-10-2004 20:57
Power Terminal Block Model Ed Sparks Inventor 1 11-02-2004 06:55
pillow blocks Jacqui Sutton Kit & Additional Hardware 1 11-01-2003 10:43
