Go to Post While a great deal in engineering is random, unknown, and often unsolvable, nothing in engineering is black magic. - TedP [more]
Unread 13-01-2007, 18:22
Inoperational Inoperational is offline
FRC #1506
Inoperational is an unknown quantity at this point
Camera Boards
Does anyone know how to use the new board as far as using servos on the new board?? We do know how to take pictures and do basic operation, but as far as the new board this year goes we do not know how to use the servos with it. Any help would be greatly appreciated.
Thanks
p.s we attached some pictures of the new and old boards.
Name:	new board.jpg
ID:	4872  Click image for larger version
Name:	old board close.jpg
Unread 13-01-2007, 18:23
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Camera Boards
You would connect the servos to the appropriate PWM outputs on the RC and code them. Or you could use Kevin Watson's camera code--it outputs the pwm signal for the servos on PWM01 and 02, I think.
JBot
Aren't signatures a bit outdated?
Unread 13-01-2007, 18:31
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Camera Boards
well they took out the 2 pwm pins on the camera board this year
so youll have to run 2 more pwm wires from your RC up to your camera this year.
yeah Im kinda disappointed too.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 13-01-2007, 19:23
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Camera Boards
Is there there a way to send Kevin's code's pwm values form the RC to the camera? I would be nice to not have to wire those to the RC if the camera is placed far.
Unread 13-01-2007, 19:39
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Camera Boards
You used to have to send 2. Now you have to send 4 (2 and then 2 for the servos).
I havent looked at the board but there is a spot where pins should be if I recall. Maybe you can use those. I havent looked at them yet so dont quote me and I also dont know the legality of doing that.
Unread 20-01-2007, 12:03
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Re: Camera Boards
All the soldier points are there but there are no pins
Unread 20-01-2007, 12:57
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Camera Boards
Although this was allowed in 2005, as I read the rules I do not believe it is legal to control servos with the camera this year (especially given that the new camera does not have the PWM headers populated). If you plan to do this I strongly advise posting it as a question on the official FIRST Q&A. Here's the relevant rule:
Originally Posted by R69
All electrical loads (motors, actuators, compressors) must be controlled by relay or PWM output signals sent by the Robot Controller to relay modules or speed controllers. Every speed controller and relay module must be connected via PWM cable to the Robot Controller, and be controlled by signals provided by the Robot Controller. They can not be controlled by signals from any other source.
A servo is a motor and therefore as I read this rule it "must be controlled by a relay or PWM output signal sent by the Robot Controller", although I will admit that the rule doesn't seem to specifically address servos (and I can't find any that do).
On second thought, I'll have my team submit a question on this, as I'm curious now myself and I'm concerned that it may come up when inspecting other robots.
OI Boards? Jake M Robot Showcase 1 28-11-2006 20:02
Control Boards (PICS) AdamHeard Robot Showcase 8 16-08-2006 16:04
Control Boards tenfour General Forum 3 01-03-2004 20:01
Message Boards w/o MySQL iBob Website Design/Showcase 7 13-07-2003 02:00
Custom Circuit Boards Billius Electrical 7 14-04-2003 12:48
