Go to Post Remember: "It's not the strongest that survive, but the most adaptable to change" - Daniel_LaFleur [more]
Unread 13-01-2007, 14:47
kaboose kaboose is offline
FRC #2227
kaboose is an unknown quantity at this point
Unhappy Wheel Designs
Does anyone know of a good way to attach the wheel and the gears together and then get them attached to the motor?
Pics and or directions would be very helpful.
Unread 13-01-2007, 19:09
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Wheel Designs
Depends on the wheels you're using. If you're using solid wheels, drilling holes in accordance to the bolt pattern of a specific kind of sprocket would be your best bet, with some polycarbonate, wood, carbon fiber, or any other material spacer to fit. Then, just bolt the sprocket on to your wheel, and that's one half of the equation.
For the other side, the BaneBots GP-56012 (The 56mm, 12:1 Planetary single motor gearbox that comes with the kit) has a nifty 1/2in wide, 4in long driveshaft with a nice little notch in the shaft that is .125in deep. That notch, which runs down the length of the shaft, can be used to hold a sproket with one of those small hex bolts in it.
Hope this helps.
-Otaku
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 16-01-2007, 18:31
FRC #2227
Re: Wheel Designs
yes it does. thanks
Unread 16-01-2007, 20:03
Agent 108's Avatar
Agent 108 Agent 108 is offline
FRC #1290 (Chandler High Robotics)
Team Role: Electrical
Agent 108 is an unknown quantity at this point
Red face Re: Wheel Designs
Last year we just put gears on the motor shaft and the axels of the wheels. Then we connected them by using a bicycle chain to connect the motors and wheels. Hope that helps a little.
Unread 16-01-2007, 21:51
Otaku's Avatar
AKA: Michael Baker
Re: Wheel Designs
Well, the size of the chain also varies. I'm not sure what kind comes with the kit, but if you use 35 chain, you best have 35 drive sprockets and 35 wheel sprockets.
I'm also pretty sure that despite the weight, most teams will go with a chain-drive system.
Thanks for adding in that little bit, though. I forgot to mention that you link it with chain.
Unread 17-01-2007, 02:30
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Wheel Designs
Attach the bigger sprockets to the kit wheels with 8-32 nuts and bolts (get these from a hardward store). Then attach the small sprocket to the output shaft of the transmission. Secure it to the shaft with shaft collars, or get some new sprockets with set screws built in. Then run your chain from sprocket to sprocket, lay it out and make a mental mark of what link will connect the two, with some slack. Break the chain and connect the two halves with a master link, and you're set.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Tri-Wheel Designs Ben Piecuch Technical Discussion 3 30-03-2004 13:03
Steerable wheel designs Max Lobovsky Technical Discussion 3 08-02-2004 14:13
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
