#8
Re: Help with the Kit Gear Tooth sensors
According to the 2007 Sensor Manual the sensor outputs a pulse, but as chris31 says the sensor should be wired to a digital input port and use interrupts - see Kevin Watson's code.
If you just try to "poll" for the state of the sensor in user_routines or even user_routines_fast, you will miss most of the pulses. Using interrupt method guarantees the pulse will be counted. Last year we mounted the sensor securly inside the tranmission gearbox - no problems. |
| where can we buy hall effect sensors or gear tooth sensors | amirjpl | Electrical | 3 | 13-02-2006 11:02 |
| Gear Tooth Sensors | et1337 | Electrical | 7 | 28-01-2006 22:48 |
| Help with Gear Tooth Sensor | RedOctober | Electrical | 3 | 27-01-2006 18:38 |
| Source for Additional Gear Tooth Sensors | Madison | Kit & Additional Hardware | 3 | 18-01-2006 16:57 |
| Accelerometer vs Gear Tooth Sensors | zdeswarte | Electrical | 4 | 22-01-2005 15:35 |
